wide 5 4 pot conversion
caddy
PostPosted: Tue Jul 10, 2007 6:38 am    Post subject: wide 5 4 pot conversion Reply with quote
i put 4 pots on the front of my 69 but i wanted to keep the 14" steel wheels .
so i made these not the prettiest but very strong, adapter made from EN8
calipers from a discovery, late bay disc reduced in diameter 8mm ,late bay hub .
they increase my track by 18mm and weigh a ton but work excellent, a big improvment over drums Grin
rusty69bus
PostPosted: Tue Jul 10, 2007 9:14 am    Post subject: Reply with quote
was the caliper a straight fit? - good old ATE Wink
PostPosted: Tue Jul 10, 2007 10:35 am    Post subject: Reply with quote
That looks like a neat conversion-did you have to reduce the thickness of the disc or the diameter? Looks good what year and model of landrover? Cheers
caddy
PostPosted: Tue Jul 10, 2007 12:45 pm    Post subject: Reply with quote
just the diameter and 93 ish discovery.
had to grind a few mm of the caliper edge they just caught the inside of the steel wheels
pugvan
PostPosted: Wed Jul 11, 2007 12:07 am    Post subject: . Reply with quote
hi mate do you know if they would fit late bay without mods and would they be an improvment over standard thanks.
caddy
PostPosted: Wed Jul 11, 2007 6:08 am    Post subject: Re: . Reply with quote
there are mods to fit them .
they are an improvment over drums , dont know about over later bay discs.
