t25 brake upgrades
Goto page Previous  1, 2, 3  Next
Covin
PostPosted: Thu May 03, 2007 8:14 am    Post subject: Reply with quote
richbaker78 wrote:
covin will be able to confirm as he had JPs old wheels and studs.
The studs used up front were Extended ones I got off jp.
The rear studs are simply the old Front studs with 10mm of the splines machined off. Very easy to do if you have access to a Lathe
Here's a picture to show things better.
Left = OG Rear Stud...Middle = OG Front Stud... Right = Machined Front Stud for Rear.
DARREN
I LOVE RUST ME
rusty69bus
PostPosted: Thu May 03, 2007 1:09 pm    Post subject: Reply with quote
where did jp get his longer front studs from?
pugvan
PostPosted: Sat May 05, 2007 12:57 am    Post subject: Reply with quote
hi covin can you tell me how fat the spline part of the stud is as i have got some merc wheels to drill out and i may as well drill them to clear the spline.
you could use a open ended spaner to mesure mm please
Covin
PostPosted: Sat May 05, 2007 7:30 am    Post subject: Reply with quote
The splines are exactly 14.85mm in diameter so I'd say 15mm clearence hole is required
DARREN
I LOVE RUST ME
pugvan
PostPosted: Sun May 06, 2007 1:32 am    Post subject: . Reply with quote
thank covin
PostPosted: Mon May 07, 2007 9:42 pm    Post subject: Reply with quote
I believe I got the extended studs from HERE if not M7 and BBT do them.
HTH
rusty69bus
PostPosted: Wed May 09, 2007 9:17 am    Post subject: Reply with quote
thanks for that jp/covin
as a side point it would appear they may be the same as porsche studs
rusty69bus
PostPosted: Wed Aug 08, 2007 2:00 pm    Post subject: Reply with quote
Bay Rear Disc Conversion Prices
rusty69bus needs
Brake backing plates £ x2
Rear wheel cylinder £ x2
Rear brake shoes £
Fitting kit x2
Keyboard shagged
rusty69bus
PostPosted: Thu Aug 09, 2007 6:04 am    Post subject: Reply with quote
back again, now my keyboard works again as i have too replace most of the rear braking parts i was wondering if anyone has done a rear disc conversion on a bay and what sort of money it cost,as i'm looking at my options.
parts i need are -
1 x Rear Backplate Type 2 August 1970 to May 1979 Offside (right)
1 x Rear Backplate Type 2 August 1970 to May 1979 Nearside (left)
1 x Set of Type 2 Rear Brake Shoes Jan 1973 - May 1979 with FREE Anti Squeel Brake Lube and FREE Brake Cleaner worth £6.94
2 x Rear Wheel Cylinder Type 2 and Type 25 August 1971 to November 1990
2 x Rear Brake Shoe Fitting Kit Type 2 August 1967 to May 1979
1 x Rear Brake Hose Type 2 August 1967 to May 1979 Offside (right)
1 x Rear Brake Hose Type 2 August 1967 to May 1979 Nearside (left)
2 x Front Brake Disc Type 2 July 1972 to May 1979
1 x Dust Cap For Bleed Nipple Type 2 and Type 25 August 1967 to November 1990
2 x Front Brake Hose Type 2 August 1970 to May 1979
4 x Flexi Brake Hose Clip Front Or Rear Type 2 and Type 25 August 1967 to November 1990
1 x Brake Pads Set of 4 Type 2 and Type 25 August 1972 to June 1986 (Thick Style)
1 x Brake Pad Fitting Kit Type 2 and Type 25 August 1972 to September 1985
2 x Axle Hub Nut Rear Type 2 & Type 25 August 1967 to November 1990
£255.68
help would be appericated Happy
PostPosted: Thu Aug 09, 2007 10:36 am    Post subject: Reply with quote
Try serching on simon Glen or custome bugs and bus's. I've seen a kit in one of the performance bus books by speedpro (a very usefull book-I have a brand new spair copy for sale for £9 if any one is interested-amazon sent me 2 by mistake!!
rusty69bus
PostPosted: Thu Aug 09, 2007 2:50 pm    Post subject: Reply with quote
have had a look, didn't find much
rusty69bus
PostPosted: Tue Dec 18, 2007 5:48 pm    Post subject: Reply with quote
it's xmas so i've been asked what i want, as i have sorted the brake out yet.......anyone what to share there brake caliper/disc's that they used for there 112/5 bay brake upgrade, should i make it dual circuit?
Page 2 of 3
