t25 brake upgrades
Goto page 1, 2, 3  Next
rusty69bus
PostPosted: Thu Mar 01, 2007 6:09 pm    Post subject: t25 brake upgrades Reply with quote
http://futbus.com/component/option,com_easygallery/Itemid,29/
this site came via brickyard,
PostPosted: Thu Mar 01, 2007 6:36 pm    Post subject: Reply with quote
Those 288mm disc's look like G60 disc's. That my plan to fit G60 discs and calipers onto my bay-very usefull to see there kits. I'm doing mine to a bay so a bit differant but hopefully not too much. Good find
PostPosted: Thu Mar 01, 2007 7:39 pm    Post subject: Reply with quote
audi a6 discs and he is doing a kit for bays and working on rears for t25 at the mo Grin
rusty69bus
PostPosted: Fri Mar 02, 2007 10:49 am    Post subject: Reply with quote
didn't notice kit for bays,i have another look
PostPosted: Fri Mar 02, 2007 9:57 pm    Post subject: Reply with quote
i dont think they are on the site but talking to dave he is looking into it Grin
futbus
PostPosted: Wed Mar 14, 2007 7:22 pm    Post subject: Reply with quote
I am looking into bays for brake upgrades. Early T25`s i believe are the same as later bays, in which case this kit will fit. Early bays looking at getting an upright so I can look at early and splits for a big disc conversion. Not all that we do is on the site although we try to add most things as we do them.
Any requests will be looked into, and at the moment seems to be bays, so watch this space. Wink
www.futbus.com
Any machining needs give us a shout on 07866 581136
Located in south devon
rusty69bus
PostPosted: Sun Apr 29, 2007 5:56 pm    Post subject: Reply with quote
hi all, you guys may know the answer i'm fitting a4 wheels to my bus, do longer t25 studs fit bay (small 5) hubs :smt017 and where can i get them from brickwerks?
PostPosted: Mon Apr 30, 2007 5:44 pm    Post subject: Reply with quote
Hi there t25 studs do fit but the spline pattern isn't exacly the same so I always tack weld them in to be safe. As far as I know there arn't any other studs that fit better. You can get them from demon tweeks though.
PostPosted: Tue May 01, 2007 7:27 am    Post subject: Reply with quote
JP used bay rear studs at the front as they are longer...you jut need to machine / grind off a little of the spline where it pokes thru a bit far.
On the back i think he used the OG studs as they were ok in length.
rusty69bus
PostPosted: Tue May 01, 2007 8:41 am    Post subject: Reply with quote
cheers i'll check the bay studs first ;)
pugvan
PostPosted: Wed May 02, 2007 1:17 am    Post subject: . Reply with quote
[quote="richbaker78"]JP used bay rear studs at the front as they are longer...you jut need to machine / grind off a little of the spline where it pokes thru a bit far.
On the back i think he used the OG studs as they were ok in length.[/qu ote]
I think its the other way round ie bay front studs used for the back and new longer studs for the front.
(standard front studs are longer than standerd rear studs )
PostPosted: Wed May 02, 2007 8:39 am    Post subject: Reply with quote
covin will be able to confirm as he had JPs old wheels and studs.
Page 1 of 3
