Posted: Mon Feb 13, 2006 2:30 pm Post subject: air suspension / air bags and shocks |
airbags etc - they send you an excellent free catalogue too......well worth a look.
http://ridetech.com/index.asp |
Alex (FTS) Jedi Guardian
Posted: Tue Feb 14, 2006 2:24 pm Post subject: Air ride 7000 spokes from airkewld.com |
Yer I got some of there airride 7000 shocks and I can highly recomend them. At the moment I only run them at 45psi with one set or torsion bars and one tork bar. I recon I will remove the other set of torsion springs when I get the compressor from you Rich and then try running them at 100psi as they recomend.
I thought I would air on the side of coursion and keep some tosion springs so I didn't over load the mounts. _________________ www.faltownskateboards.com |
Matty Force Sensitive
Posted: Thu Mar 01, 2007 9:10 pm Post subject: |
So, if you're running air shocks, and no torsion bars, it's basically the same set up as the red9design kit? except you've got air shocks instead of basic coil overs? i bought a red9 kit for my '71 - but i'm not so sure i wanna run around with all the weight on 2 shock bolts :smt095
i'd love an air ride on the bay - i'll have a look on the site now.
In theory you could weld a heavy duty shock mount to the outside of the chassis rails.. or since i'm having a narrowed beam with custom endplates, i can incorporate a decent mount on them too... hmmmm  |
Posted: Fri Mar 02, 2007 9:34 am Post subject: |
matty - yes what you say is right -you would rely on the bolt only which can be a bit scary when it comes undone eh alex .
I have fitted air bags to mine rather than airshocks.....this was once available as a kit from Max hydraulics before they closed shop. I bought a 2nd hand kit and junked most of it except the components as it just bloted onto varius bits of the beam - fine if its not narrowed....but like you I have a narrowed beam and it was a bit of a headache.
basically i created a proper bag mounting but scollping out the chassis - i did this at the back too......im pleasedwith the end result but it think if starting all over again i would prob use t25 suspension as that will take bags much easier. |
rusty69bus Jedi Master
Posted: Fri Mar 02, 2007 12:48 pm Post subject: |
Wow that is quite some system! Very impresive indeed. Appart from the bolt coming off one time and the shock pinging off I havent had any problems with strength. Although I have beefed up the top mount and one day I will beef up the bottom mount-like Rich has.
Yer the system is very similar to the rednine one apart from I am running the top set of toursion bars still and now an antirolebar which really does make everything run smoothly. I have also adjusted the damping on the shocks to take into consideration the extra stiffness. _________________ www.faltownskateboards.com |
