Posted: Wed Mar 15, 2006 3:22 pm Post subject: newer engines?
new to this conversion game and been looking for the right engine. Saw a mk5 tdi from a golf with 8000 miles on it but with ecu and starter issues I thought the job was prob too big...
so what type of engine?
are ecu's a nightmare and don't most newer engines have them?
is there a way round these problems?
aren't old engines nearing their life span with 100,000's of miles on them?
I want my bus to go well, have better mpg than my 1600,be reliable and allow me to drive the dam thing!!!!
any advice would be appriciated
Posted: Wed Mar 15, 2006 4:24 pm Post subject: Re: newer engines?
worse prob is removeing the engine loom,ecu and key transponder if it has one (esay way change injector 4 a manual cable type dose the job and works great.
Posted: Thu Dec 28, 2006 10:11 pm Post subject: tdi
there's a chap not to far from me and he has a t25 syncro with a modern TDI vw engine fitted and the fuel pump he used was off a citreon xantia 2.1 td , i also know of another with discovery 200 tdi pump , recalibrated just a mater of reducing the amount of fuel , the old meastro and montego pumps should also be ok if bosche
_________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington
