Bigger wheels - does it make a difference?
t2gus
PostPosted: Sun Sep 09, 2012 8:57 am    Post subject: Bigger wheels - does it make a difference? Reply with quote
My t2 camper is running on 15inch wheels
Will going up to 16/17 really make a difference to engine revs, mpg, speed?
If so, what tyre size to go with? I'm thinking 16inch would look better than 17
Where can I get 16inch wheels that suit and fit with no modification?
72panelvan
PostPosted: Thu Sep 13, 2012 5:20 pm    Post subject: Reply with quote
have a play on something like this http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
I've found upping the tyre size sorted out my van no end, cruises at 60 very happily now. Went from 185 70 14 at the back to 195 70 15. Not a huge difference (60mph to 64mph at the same revs) but it's really noticeable through the gears. I'd go bigger but the tyres are good which came with the steelies.
Jristrogy
PostPosted: Fri Sep 02, 2016 5:25 am    Post subject: Reply with quote
I know you are very experienced in this matter very seriously.
SelmaAdam
PostPosted: Tue May 25, 2021 7:00 am    Post subject: Reply with quote
There's a difference:Bigger tires and wheels are better for increasing your vehicle's traction. Changing to larger tires with an improper sidewall height can cause damage to your vehicle's suspension system, wheels, and the tires themselves, and can run the risk of incorrect speedometer readings.
my response | original site | useful reference | the author
