Which is the ECU permanent KAM live
dialarcs
PostPosted: Thu Jul 21, 2016 1:29 pm    Post subject: Which is the ECU permanent KAM live Reply with quote
Hi all, after being inspired by you guys I've embarked on a scuby upgrade to my 1970 early bay.
I can't work out (probably missing something realy obvious) which wire is the perm live for the ecu.
My ecu code: A18-000 D40 from a 1995/6 non-turbo Impreza Estate
Any help would be gratefully received. help ta
panel
PostPosted: Sat Aug 06, 2016 4:42 am    Post subject: Reply with quote
Do you have the wiring diagram for it?
EJ20 Turbo bus build
dialarcs
PostPosted: Tue Aug 09, 2016 3:51 pm    Post subject: Reply with quote
Massive thank you to 1Kingy79 for helping
Results:
22pin Ecu connector pin 11 is ignition live
26pin Ecu connector pin 15 is perm live
1Kingy79
PostPosted: Wed Aug 10, 2016 5:40 pm    Post subject: Reply with quote
No problem
