busbuddy Force Sensitive
Posted: Sat Jan 09, 2016 8:38 pm Post subject: |
maf is always my first choice to start detecting any fault
dont always throw a fault because the maf is first source of air info for the ecu, the ecu adapts to info the maf sends |
skirk Jedi Knight
Joined: 05 Sep 2011 Posts: 105 Location: Leicestershire
Posted: Tue Jan 12, 2016 1:56 pm Post subject: |
| busbuddy wrote: | maf is always my first choice to start detecting any fault
Thanks to you we didn't faff around too long. Cheers. |
trev Jedi Master
Posted: Sat Apr 09, 2016 7:26 pm Post subject: |
| what kind of ground clearance do you have below the sump? |
Wilfred Darth Admin
Posted: Sun Apr 10, 2016 4:58 pm Post subject: |
I have virtually the same conversion, and I have about 17 centimeters clearance. _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
trev Jedi Master
Posted: Sun Apr 10, 2016 8:11 pm Post subject: |
thanks Wilfred. I've started my TDI + flipped Passat box conversion and I've landed on a best sump height versus CV angle of about 7"/175mm so it's good to know I'm in the right ballpark!  |
skirk Jedi Knight
Posted: Mon Apr 11, 2016 9:11 am Post subject: |
| Sorry. Missed this. I haven't measured mine but looks around the clearance mentioned here. Going to put some 15'' Banded rims on the back in the next few weeks. |
splitbusvanatic Jedi Master
Posted: Sun Apr 17, 2016 11:30 am Post subject: |
Anyone look into modifying the sump. ? Make it a little less deep ?
I know dark side developments do one but is it suitable for AFN and are its benefits only that it's a steel item and not ally. Ie. Not much of a saving in height. |
trev Jedi Master
Posted: Mon Apr 18, 2016 7:49 pm Post subject: |
no point Dan, the gearbox bellhousing and flywheel are just as low as the sump. Maybe not as far back from the wheels as the sump so probably less vulnerable to coming off a speedhump hard but they're just as low  |
Wilfred Darth Admin
Posted: Tue Apr 19, 2016 1:37 pm Post subject: |
the sump is absolutely not the lowest point, so adjusting the sump is not needed. I have a baywindow, with an AFN engine, and ground clearance is no issue for me at all. Maybe if your ride is lowered, there could be problems. _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
Posted: Wed Apr 20, 2016 1:29 pm Post subject: |
I suppose it just looks low.
I had another look there and indeed it is the adapter plate and bell housing that hang down most alright. |
