atlas2l8v Force Sensitive
Posted: Sat Feb 27, 2016 3:39 pm Post subject: Starter/Alternator wiring subaru beetle conversion |
Been cracking on with my conversion and got a couple queries re the wiring..if someone can check the picture to see if the connections are correct i would appreciate it.
Im using
- Ej25 engine (was auto box)
- Beetle starter motor
- Subaru Alternator
I'm also using a ignition live and battery distribution fuse boxes for the connections from the ecu etc. As ive kept the alternator ring terminal white wires that split into 2 can i use one wire to provide the permanent live to the distribution box and the other to the battery, and can i use the existing beetle coil wire to provide igntion live to the ignition live distribution box ?
thanks |
Posted: Sun Feb 28, 2016 9:17 am Post subject: |
From memory that's very much how mine is.
Don't forget the about the cold start circuit. _________________ Think......
