Cut raised stub axles
KARMAD
PostPosted: Fri Feb 12, 2016 2:26 pm    Post subject: Cut raised stub axles Reply with quote
Hi just reading volksworld mag on James Austin's Tdi split .He cut and raised his stub axles to get a 3 inch drop which is normally not possible with a flipped passat box .I cant figure how this is done and can't find any pictures .I really want to do this with my bus .can anyone help with pics please
KARMAD
PostPosted: Sun Feb 14, 2016 3:52 pm    Post subject: Reply with quote
Anyone out there that can give me any info please
trev
PostPosted: Sun Feb 14, 2016 10:56 pm    Post subject: Reply with quote
unbelievable! 18 photos of the van and none of the dirty bits that might be interesting!!
http://www.vwcamperandbus.com/wallpaper/1960-split-screen-westfalia-17955
Quote:
Putting the power to the ground are a pair of Beetle driveshafts, attached to a machined output flange on the right and a spacer / converter on the left, whilst the rear suspension consists of Beetle IRS trailing arms attached to cut, raised and braced stub axles giving an immediate three-inch drop
trev
PostPosted: Sun Feb 14, 2016 10:59 pm    Post subject: Reply with quote
I can't figure out what they're describing either though.
I PM'd you on Facebook Graham, did you get it?
KARMAD
PostPosted: Sun Feb 14, 2016 11:32 pm    Post subject: Reply with quote
Exactly Trevor my thoughts too .been trying to figure did he cut and raise the torsion bar where the bolt on brackets for the irs would be
splitbusvanatic
PostPosted: Sat Feb 20, 2016 12:55 am    Post subject: Reply with quote
Have a look at this thread fellas.
It's a curveball that you may be able to help with Graham.
http://www.thesamba.com/vw/forum/viewtopic.php?t=374289&postdays=0&postorder=asc&start=0
splitbusvanatic
PostPosted: Sat Feb 20, 2016 1:01 am    Post subject: Reply with quote
http://www.mudtrials.org/thetrialscar41.htm
