LOOKING FOR A SHORTENED SUMP FOR EJ22
KARMAD
PostPosted: Thu Mar 22, 2012 2:27 pm    Post subject: LOOKING FOR A SHORTENED SUMP FOR EJ22 Reply with quote
Hi lads if anyone has a shortened originalor cast sump knocking around could you get in touch Happy
leeroy
PostPosted: Thu Mar 29, 2012 8:32 pm    Post subject: Reply with quote
Looking at doing mine soon I found this
http://www.outfrontmotorsports.com/oil_pan.htm
Seems the cheapest way I will post pics when done .
1965 south african kombi in lots of bits ej22 lying in wait.
AirWRX
Location: In the East of the Anglia! but mostly at work!!
PostPosted: Sat Jul 14, 2012 11:06 pm    Post subject: Reply with quote
I have been working on one over the last couple of days, its a bit bigger in capacity, really thick steel so should be tough enough, uses stock drain tube, baffle, dip stick and even sump plug. im will post some pics when its done.
leeroy
PostPosted: Tue Nov 05, 2013 8:36 pm    Post subject: Tig welded sump relocated drain plug Reply with quote
Followed outfronts method made a 3mm base plate and tig welded it fully, then re located the drain bolt finally a leak test that was all good.
Hopefully it will work if not looks nice. pics to follow [/url]
Jzgerman
PostPosted: Tue Dec 01, 2015 8:13 am    Post subject: Reply with quote
I do not know what's good for you, but I will try it.
