Subaru Fuel pump in Bay fuel tank
SCOO-BAY-BLUE
PostPosted: Sun Oct 11, 2015 6:14 pm    Post subject: Subaru Fuel pump in Bay fuel tank Reply with quote
Hi, I have a 1974 VW Bay 1800 cc type 4 that I am converting to run a ej22 2.2l N/A Subaru engine.1998
As I have the fuel pump already could I convert the bay tank or would there be any known problems ?
I'm sure I saw a photo somewhere on a website but forgot to save it .
Wilfred
PostPosted: Mon Oct 12, 2015 6:31 am    Post subject: Reply with quote
Hey,
yeah you can just weld them together. Look here: http://vwkd.com/bb/viewtopic.php?t=302&postdays=0&postorder=asc&start=24
PostPosted: Fri Oct 16, 2015 9:11 pm    Post subject: Reply with quote
Yes either weld the Subaru fuel pump into the top of the bay tank or modify the bay tank to have a 12mm outlet feeding a Bosch 044 pump.
1303Steve
PostPosted: Sat Oct 17, 2015 8:11 am    Post subject: Reply with quote
Hi
Didn't you get late bays with EFI where you are? You could just use a tank from one of them, they used an external pump but had a return line and built in surge section?
Steve
STI powered 1303 now running
VW_Kraft_Dinner
PostPosted: Wed Nov 18, 2015 6:51 pm    Post subject: Reply with quote
What's the reason that the outlet needs to be 12mm when the Subaru supply line is 8mm?
