Posted: Sat Sep 26, 2015 12:04 am Post subject:
Try putting an LED test light or mutli meter on the 2 plugs to see if it flashes, should be 12 volt one side and an ECU earthing pulse the other side, if no flash put the test light to 12 volt like your battery connection on the alternator, if still no flash go back to the ECU connector _________________ STI powered 1303 now running
