best gearbox
tracktony
PostPosted: Wed Sep 23, 2015 3:58 pm    Post subject: best gearbox Reply with quote
ok got my bus up and running at last with a 2.0 golf gti enfine running an adaptor onto a 3 rib gearbox , problem is the ratios I,m doing over 3k revs at 50mph . I,m not great with mechanice and need to know what box or best solution for me please so I can buy whatevers needed thanks tony
PostPosted: Wed Sep 23, 2015 8:06 pm    Post subject: Reply with quote
Flipped Passat box seeing as your already running an in line 4 engine.
Or a petrol t25 box maybe.
megabus
PostPosted: Wed Sep 23, 2015 9:45 pm    Post subject: gti stuff Reply with quote
hi there any pics of your conversion,I'm doing the same thing.what engine did you use and what year is the engine.Also which adapter plate did you use. how easy was the wiring to sort out.Sorry for all the questions thanks Ian
Wilfred
PostPosted: Thu Sep 24, 2015 6:34 am    Post subject: Reply with quote
You could go for bigger tires...
recently, I put some huge ass tires under my van.
https://lh3.googleusercontent.com/6khsiZK5EnwB9PkRPW21yFNoJO6FbtzwGqoPrC4Y5yNottel7YFBfONN-vRAEKYLOFFtMNX3-07cyMPDaPL0_y3t9xi9KpzOXuVYgIn0uNZ9MI0H1FeNYvUMBow3vS6Euig-d7swyy78r5uXGBWiFNeVFky3eH7OVB2b9JbHLmryQLXRfQuo5CPA0NyMhHAi1EF8kHA9hiR79zUL37fzjxgbHJO89Q5kdqRo74jhtWsVQAdZT0bEZa2xZU2PNQu7uXWRrrB3_8bxD5kiHFQQiGE5Bha_zDSnhqibm2vaGFcBodWtijhlGLyzXnPG0MDyQqLhX0A5Bu6jF3DQk035Rtg9gcpSvpSrghzOuzC4hWZH1aFL5LZi3iUgoETHeiLM3tpnd4pp7igssuGqzV84gh1Dl21TGzrAoiRjCxTiysmc5U6CuAFeg0CRB9Epf_5YFY_8YfgbpeH3vOdTth8LRKtHKpADkyWlSIiPV2L8YRwHKCGSYs9cfBSEvWRYPlEXFX_27fj744EIIoNnnqO5qrlv2iAh5890_eKL-8pXZWk=w1632-h918-no
Too big though. The van was getting slow. But I was amazed at the difference these tires make. Size is 205/80R16
There are some mercedes rims you can use. These have same ET and bolt layout, and are available at 16 inch. I used these ass well.
tracktony
PostPosted: Thu Sep 24, 2015 9:50 pm    Post subject: Reply with quote
Will the t25 gearbox fit ok , found one with a dk code but the clutch is on the side not like my bay 3 rib
tracktony
PostPosted: Thu Sep 24, 2015 9:52 pm    Post subject: Re: gti stuff Reply with quote
. Will get some tomorrow but tbh someone did the conversion for me so not clued up on what he did sorry
PostPosted: Fri Sep 25, 2015 9:53 am    Post subject: Reply with quote
Is it a t25 bus you have then?
With your 3 rib box. As Wilfred said you can stick some bigger rear tyres on it which will drop the revs down. Another solution is to change the final drive ring gear on the diff inside the 3 rib gearbox. This will also drop the revs. Could be cheaper then going into a complete gearbox transfer.
