Bay Window with 1.9 TDI engine -> READY
Goto page Previous  1, 2, 3 ... 10, 11, 12 ... 20, 21, 22  Next
Wilfred
PostPosted: Wed Jul 29, 2015 7:23 am    Post subject: Reply with quote
Well, I found an error.
I had a bit of an oil leak. Couldn't really find out where it came from.
But then yesterday, I crawled under the bus, immediately after a 30 km drive. I noticed a trail going up along the gearbox....
tight spot, but took some pics to try if I could see something:
https://lh3.googleusercontent.com/fX3Ya39e227f30IuNuc9gTdb8c-4g-bTLXRnGHrEMSw=w1632-h918-no
Pic if what is now the top of the gearbox. The green cap is used to cover the breather hole, which is drilled in the old draining plug.
Unfortunately, I made the breather way to big, so oil is splashing out. I really underestimated how much splatter there would be. you can see the oil between the ribs of the box.
luckily, this is a simple fix. I just have to alter the breather hole. Think I am gonne use a small hose.
glad I found out now, it could ruin the gearbox. I am also gonna ad some gearbox oil. think I may have lost a couple dL.
Wilfred
PostPosted: Mon Aug 03, 2015 7:04 am    Post subject: Reply with quote
I still have to properly fix gearbox breather. other than that, the bus has done well last weekend!
https://lh3.googleusercontent.com/NhqQmh3xiPRwbHUBabS16Cpv8BCYipQBhZFf_vfTnEs=w1632-h918-no
https://lh3.googleusercontent.com/SWdduVVgbzDfGVZfZofmyCxos8kpwm8hsY788auOUX8=w1632-h918-no
short camping trip, about 2 hours from our house in a lovely village. Bit of biking, canoeing etc... That was just wonderful. 120 kph on the highway no problem, although it won't go really faster which I find strange.
Any way, on the way back I got to test the cooling system. Heavy traffic due to an accident:
https://lh3.googleusercontent.com/Ty5eFOlBQ2VaCAwa_UQU0Gp3wuZE4juyE1QpgxvS2yI=w803-h511-no
https://lh3.googleusercontent.com/cBVM_ERrCf_fAs3-FN1CLPYpVSAlGnSfTf3dlJ-ElTA=w805-h532-no
And us somewhere here, for half an hour:
https://lh3.googleusercontent.com/bLukF8-G6yXJ9Cf9_AbQpXePHP9o-GZj1cuYtqAExjM=w807-h531-no
The temperature slowly went up and up and up but not too high. Although I am not sure the fans came on or not. I need to install a light which will go on when fans rotate. Now I just don't know but anyway, heacy traffic, about 27 degrees celcius.... no problem!
Wilfred
PostPosted: Sat Aug 08, 2015 8:41 pm    Post subject: Reply with quote
Today I got a lot done. I never knew that the breather for the box was a common issue with this conversion, and nobody bothered to tell me over here...First I had e thin hose but that is no good as a drop can close of the breather and is then easily pushed out.
This is what I made now:
https://lh3.googleusercontent.com/48Ym9QGHz0Ab3olwpSLvgXYUP5KWISZ_NU2BWpbVd_4=w1632-h918-no
https://lh3.googleusercontent.com/og5hQJQi8S4f4on8Xb_m2uaxnvEebCRQaT4CEbWP1Yo=w1632-h918-no
https://lh3.googleusercontent.com/3KuwEFVsxobThTmBOyoSm5jkzt4zfJ1kFOerqVxBTjs=w1632-h918-no
https://lh3.googleusercontent.com/vlydr4dwNzKNHYdl5hQqUXZJgKJZHbKRi1IMYq0WqIo=w1632-h918-no
I also removed the steering pump. The tensionor for the timing belt is excellent for this. Fits right in the spot of the lower bolt for the steering pump. Using a couple of washers put it exactly in line with the other pulleys. Runs very smooth!
https://lh3.googleusercontent.com/4S50DmIy0mI_JklpnQD6qQEbmR4P86xy8KgYcP4yNOY=w1632-h918-no
https://lh3.googleusercontent.com/yDHzRjXFf-LCW-ZbDGz14pF6AkomlsTLeU9afrixHCg=w517-h919-no
https://lh3.googleusercontent.com/SJ6cDG22H-sYS8E20tKj5f-F18Xkw-M41ZaQ2QT_Jhs=w517-h919-no
Then I removed the EGR:
https://lh3.googleusercontent.com/hQaUQ3cfuVMbHHvj_hviMcyTsis3pbKaa9OIvv_DOOY=w1632-h918-no
https://lh3.googleusercontent.com/IWAxClqTgFMAsHGURTXuFr18Nn_rpfto5_xhDfTF9Ww=w1632-h918-no
And finally I noticed my engine mount is hitting my sump!!! I feel lucky I saw it cause I dont think this would have lasted for another 1000 km.
https://lh3.googleusercontent.com/0NH9Hnb69_CUbE7CID4RJW2hHi16VyNx5RzEcJ6dLTQ=w1632-h918-no
https://lh3.googleusercontent.com/mERNkdiV3L-PH9IQbuMhi2JSzpxWFgOPx34609XsQQ0=w1632-h918-no
https://lh3.googleusercontent.com/PKTZF6wio5g2HxcjKy4qf9RK-bq3czoypUEq07XIgEM=w517-h919-no
Dont bother all the oil. Just gearbox oil from last camping trip. Silly me had the faulty breather ending up right on top of the engine... what a mess!!!!!
I cleaned it today, hoping it will stay dray now!
splitbusvanatic
PostPosted: Sun Aug 09, 2015 12:54 am    Post subject: Reply with quote
splitbusvanatic wrote:
Great update.
You must be smiling from ear to ear.
What length of pipe did you use for your gearbox oil breather ? And did you put a catch tank on it or just mount it really high ?
Thanks.
Congratulations again by the way.
Maybe I should have made it more clear that the gearbox oil is a problem on the flipped box, good job on the pipe and catch tank you have made. I also Like the idea for the steering pump replacement.
Wilfred
PostPosted: Sun Aug 09, 2015 8:25 am    Post subject: Reply with quote
Haha, don't worry mate. This forum has been a great help.
But indeed, from your remark I didn't get that the a leaky breather was actually a common problem when you use the drain plug for a breather.
last week I googled something like 'flipped box passat gearbox oil breather' and ended up on the brickyard where there is topic about this. That is also where I got the Brillo idea (the steel in the filter).
I think, if I would do it again, I would look at the internals of the gearbox and drill a small hole in a spot where there are no gears turning really fast and pushing oil out.
skirk
PostPosted: Tue Aug 11, 2015 2:19 pm    Post subject: Reply with quote
Glad you are getting sorted. Have you wired up your reverse lights to the wiring on the gearbox ? Can't seem to get mine working.
Wilfred
PostPosted: Tue Aug 11, 2015 3:10 pm    Post subject: Reply with quote
No, haven't tried yet.
I just figured out yesterday those wires were leaning on my exhaust... burned a bit now :-)
Wilfred
PostPosted: Fri Sep 04, 2015 11:44 am    Post subject: Reply with quote
One thing that can happen when you install a TDI, is that your turbo might fail...
on the way to Italy...
which means you have to be towed home cause you loose faith in the van very quick...
and instead you have to book a last minute to the Greek island Rhodos, which was wonderful!
pics of the bad turbo. Did I just have bad luck that it happened to fail on this particular moment, or dit I do something that caused the turbo to fail...
klik
klik
klik
Wilfred
PostPosted: Fri Sep 04, 2015 6:56 pm    Post subject: Reply with quote
oh, and this is the sound a turbo can make before it dies:
VIDEO
PostPosted: Fri Sep 04, 2015 7:34 pm    Post subject: Reply with quote
If you'd have read my thread you'd have known about the breather, talked about it ages ago... ..
Gutted for ya dude Sad .. where abouts in Italy were you headed for?
We just got back from near Jesolo ( about 40km from Venice..
Hope you get it sorted soon
Wilfred
PostPosted: Sat Sep 05, 2015 7:47 am    Post subject: Reply with quote
haha no worries, I did read about the breather. But I can't find a solution here. And I thought it wouldn't be a big problem. But it is.
On the faulty turbo... I had a feeling it wat failing, that is also why I made the film when it made a different noise. BUt still we decided to go to italy.
We choose the route so we would pass my parents, about an hour from my house. It popped 20 km before their house, so was an easy tow and I tucked it away so we could go to greece.
Don't feel gutted for me, spending my time in lovely weahter on a white sandy beach! I had the best holiday!
Searching for a replacement turbo now. Going for the 130 or 150 bhp version!
Wilfred
PostPosted: Sat Sep 12, 2015 7:21 pm    Post subject: Reply with quote
Fitted new turbo today and the TDI engine runs like never before!
Ticking up the miles again!
Page 11 of 22
