Factory RPM/rev counter?
DonTPushIt
PostPosted: Sun Apr 26, 2015 11:21 pm    Post subject: Factory RPM/rev counter? Reply with quote
I currently run an aftermarket rev counter with my 1985 T25 2.0i ej20 setup - how do I get my VW rev counter to work instead?
PostPosted: Thu May 14, 2015 8:30 am    Post subject: Reply with quote
What was the engine originally in your van? Petrol or diesel?
DonTPushIt
PostPosted: Thu May 14, 2015 8:35 am    Post subject: Reply with quote
Petrol
PostPosted: Thu May 14, 2015 9:56 am    Post subject: Reply with quote
Originally, your VW petrol rev counter would have been connected to the coil. You need to find this wire.
The Subaru ecu has a tachometer output, find that. Connected to the VW tachometer wire which would be near the old coil location.
Presumably your aftermarket rev counter is using additional installed wiring?
DonTPushIt
PostPosted: Thu May 14, 2015 10:11 am    Post subject: Reply with quote
Hi Kai,
Yes, the aftermarket rev counter is wired in and working correctly - can I just use this wiring?
Why would this not have been done originally? I think I read somewhere that Richard RJES said he shy's away from it?
Thanks,
Rory
Wilfred
PostPosted: Thu May 14, 2015 10:57 am    Post subject: Reply with quote
I don't think the VW tachometer will work with the subaru signal. modern engines have entirely different meters. So called air-core meters. The impuls signal is transformed into a current which drives the signal.
The signal also doens't come from the coil anymore (as in the VW) but from the crankshaft position sensor. Different signal
PostPosted: Mon May 18, 2015 10:51 am    Post subject: Reply with quote
I didn't know that ^^^^^
But if this is the case then my Subaru ecu shouldn't be able to drive my 1985 Porsche 924rev counter....., I don't think the Porsche was running a crank sensor then but then again I could be wrong on that also.
Besides all that, the OP has all the components and only had to swap one wire. No harm in trying is there?
Wilfred
PostPosted: Mon May 18, 2015 10:57 am    Post subject: Reply with quote
True! just give it a try.
I recently worked on some tachometers but it could depend on the type and year of car.
Does subare has coil on plug or distributor cap?
PostPosted: Mon May 18, 2015 10:59 am    Post subject: Reply with quote
Wilfred is correct in his uber technical knowledge.
Read the last post from RJES himself.
http://www.brick-yard.co.uk/forum/ej22-rev-counter_topic41523.html
andymcc
PostPosted: Wed May 20, 2015 8:47 pm    Post subject: Reply with quote
The dash panels used by VW in later vehicles such as the late-90's Golf and Passat are compatible with the Subaru tach signal. This is one of the reasons I developed my upgrade kit.
HTH
1990 VW 252 EJ25
1990 VW 246 AFN
syncrosport.com
Volkswagen Transporter, reloaded.
DonTPushIt
PostPosted: Wed May 20, 2015 9:07 pm    Post subject: Reply with quote
Purchased a rpm module convertor from RJES. Fitting soon.
mackaymanx
PostPosted: Thu May 21, 2015 5:24 am    Post subject: Reply with quote
There is a mod you can do to the VW tacho to make it compatible with the Subaru tacho signal.
http://www.thesamba.com/vw/forum/viewtopic.php?t=517384&start=323
