Fuel Pump/Relay Supply Voltage
Sydney
PostPosted: Sat Apr 11, 2015 11:12 pm    Post subject: Fuel Pump/Relay Supply Voltage Reply with quote
EJ20 N/A.
Had a problem with fuel delivery today. Battery voltage was at 12.2V. Turned on the ignition but didn't hear the usual noise of the pump priming. Turned the key to start and the engine turned easily but wouldn't fire. After trying a few times with the same result I then connected jumper leads from the car with its engine running. The voltage was now at 13V and the bus started straight away and continued to run normally.
I wasn't brave enough to drive it so put the battery on charge overnight and will try it again tomorrow. Is it possible that 12.2V was too low to operate the fuel pump or might this be an intermittent wiring issue?
Sydney
PostPosted: Sun Apr 12, 2015 3:17 pm    Post subject: Reply with quote
Today, with the battery charged and reading 12.5V everything worked fine. The fuel pump primes momentarily when the ignition is switched on, and the engine starts easily when the starter is engaged.
Surely 12.2V isn't too low for the fuel pump relay or the ECU to operate.
Could this just be a sticking fuel relay?
Has anyone had this issue before?
Thanks
Wilfred
PostPosted: Sun Apr 12, 2015 4:37 pm    Post subject: Reply with quote
Your battery is dying. Modern technology is very sensitive regarding volts.
If it happens again, charge batter again and see if that works again. Than you know almost sure it is the voltage.
PostPosted: Sun Apr 12, 2015 8:33 pm    Post subject: Reply with quote
Yeah try a different battery on it.
Your own Investigations shows points towoards a suspect battery.
If the bus had xenon hid bulbs fitted it would definetly of behaved the same way as in on or off.
Sydney
PostPosted: Sun Apr 12, 2015 9:44 pm    Post subject: Reply with quote
Thanks guys. A new battery it is then. i think I'll order a spare pump relay as well just to be on the safe side, if I can find the right one.
Thanks again.
Sydney
PostPosted: Wed Apr 15, 2015 6:41 pm    Post subject: Reply with quote
Does anyone know where I can get hold of a new EJ20 N/A fuel pump relay?
It's just to keep as a spare but I can't find any on t'internet.
PostPosted: Thu Apr 16, 2015 5:49 am    Post subject: Reply with quote
It's just s standard type of relay. Nothing special. Just would need a different plug put onto it.
Breakers is going to be your best bet of you wanted a Subaru one. Grade A Subaru.
Sydney
PostPosted: Fri Apr 17, 2015 7:48 pm    Post subject: Reply with quote
Thanks Kai, I managed to get one on EBay. I wanted an original so it would be easy to replace in an emergency.
It all seems to be working OK at the moment.
Thanks again.
