Posted: Sat Mar 21, 2015 3:06 pm Post subject: Subaru conversion parts inc plate kit, MS2, sump,HD starter
Hi
I have some parts for sale that are left from my Subaru Bug conversion.
The parts are new but have been in storage for some time.
I can take all parts to Volksworld Show - only live a few miles away in SW London.
1. Conversion plate + flywheel + nuts&bolts (new) -sold
The kit is brand new and never fitted. There is no bearing in the flywheel in the pict but it is included in the kit.
Price is £380 collecetd or £420 posted
2. Shortened, alloy sump (new) -sold
I bought it a couple of years ago and it's been in storage since. It's got some scratches from storage. I've measured it's capacity and it contains 3.9L before it overflows form the dip stick's entry - see picts.
Here is some good info about Subaru oil sump and oil capacity:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7175302
3. Megasquirt 2 PCB3 with JimStim, wiring Harness, fuse box, relays, comp. connection cables, additional sensors, Subaru igniter, 36-2-2-2 trigger wheel, NB lambda.
It's been pre setup for:
external ignitor, 36-2-2-2 trigger wheel, wasted spark, VR sensor, MS extra software.
It's not Plug&Play, still needs additional modes.
Price £520 collected including manifolds gaskets seen in pict.
4. High torque starter motor
Starter is also new, never fitted, it has a split in wiring insulation - see pict.
