popout Force Sensitive
Posted: Tue Nov 04, 2014 5:10 pm Post subject: lowering rear.... |
Had a search but cant really find out... Putting a ej20 into a late bay with a a fellows lowered sump, whats a sensible height to lower it by? Im thinking couple of inches would be ok, do I use lowered spring plates or just turn the original spring plates a spline .Going for a red9 coil over up front...when ive saved some pennies
cheers Tim |
Posted: Fri Nov 07, 2014 8:01 am Post subject: |
| I would say 1 outer spline is sensible, 2 is low, 3 s madness :-) however it is a matter of opinion and will depend how much sag the back of your van has to start with, the weight you will carry and how heavy your interioi is etc. I wouldn't bother buying adjustable plates really since its so easy to lower the std suspension. Especially since fitting them will require you to do the same amount of work as lowering. |
Posted: Fri Nov 07, 2014 6:06 pm Post subject: |
Thanks, that what I was thinking. I meant to say rad was up front so just have to worry about sump clearance really. Didn't want to spend £180-220 when I can just turn to springplate  |
