Iacv pipe advice please.
ping
PostPosted: Thu Oct 02, 2014 7:39 am    Post subject: Iacv pipe advice please. Reply with quote
Where do you have your iacv pipe connected to? Does it have to go in it a resonator box or can it just go to the air intake pipe after the maf?
PostPosted: Fri Oct 03, 2014 9:49 am    Post subject: Reply with quote
Just into the air intake pipe.
ping
PostPosted: Fri Oct 03, 2014 11:55 am    Post subject: Reply with quote
Cheers. I wasn't sure if it had to be a certain lengh or what not.
PostPosted: Fri Oct 03, 2014 12:05 pm    Post subject: Reply with quote
No the idle control valve is basically a bypass to the throttle butterfly, basically it's a choke which is controlled by the ecu. Therefor it's only requirement is that it must use measured air after the MAF.
ping
PostPosted: Fri Oct 03, 2014 12:37 pm    Post subject: Reply with quote
Thanks Kai, my engine is starting to come together now, it's taking a while due to other projects tho!
