Subaru/VW adapter plate problems/clearance with bolt heads
panel
PostPosted: Tue Jul 22, 2014 11:11 pm    Post subject: Subaru/VW adapter plate problems/clearance with bolt heads Reply with quote
Looks like I have a little clearance problems with the bottom two bolts. Is this common? If so what do I do? This wont let me push it all the way in.
EJ20 Turbo bus build
mackaymanx
PostPosted: Tue Jul 22, 2014 11:12 pm    Post subject: Reply with quote
Cut a channel in the mount for the bolt head.
panel
PostPosted: Wed Jul 23, 2014 1:08 am    Post subject: Reply with quote
So it's common ? Sounds good will do.
mackaymanx
PostPosted: Wed Jul 23, 2014 8:17 am    Post subject: Reply with quote
That is the cheap solution or countersink the holes and see if these are still available http://vwkd.com/bb/viewtopic.php?t=4551&start=0&postdays=0&postorder=asc&highlight=metric+fine
