popout Force Sensitive
Posted: Thu Nov 14, 2013 8:39 am Post subject: Subaru calipers/sharan disc's |
Ive read posts about using Legacy front calipers and Sharan disc's as a cheap front brake upgrade. Does it have to be Legacy calipers or ones from Impreza etc the same?
Do I need the 4 pots?
or 2 pots?
I know I need to make mounting brackets for them. Has anyone any pics of them fitted to a Baywindow?
Cheers Tim |
Posted: Thu Jan 01, 2015 10:28 am Post subject: |
| Done this with not too much hassle, used 400mm x 20mm steel bar. Had to grind out a bit on the back in the middle as the face on the spindle isn't flat, but simple enough. Sink the bolts holding the bracket to the callipers and tap the bracket to bolt to the spindle using the original calliper bolt holes. Used the callipers of the Forester and 288mm vented discs for a vw Sharan |
trev Jedi Master
Posted: Thu Jan 01, 2015 11:56 am Post subject: |
thanks for sharing Popout
did the Sharan disks go straight on in place of the bay window fronts? |
Posted: Thu Jan 01, 2015 12:17 pm Post subject: |
| yes, but the sharan discs really need the 2 locating bolts so need the drill the hub for the second. I'll take some pics tomorrow. Had to use 16" wheels to clear the callipers, some 15" may fit but thought it was a bit tight. Using the Forester hoses too, there's 2 joined together so long enough to go from calliper to the hard brake pipe. |
trev Jedi Master
Posted: Thu Jan 01, 2015 7:15 pm Post subject: |
| look forward to the pics, thanks |
Posted: Fri Jan 02, 2015 1:47 pm Post subject: |
trev Jedi Master
Posted: Fri Jan 02, 2015 3:53 pm Post subject: |
| that's a lot of disk!! Is the whole pad touching the disk? |
Posted: Fri Jan 02, 2015 5:14 pm Post subject: |
Not sure what you mean, how can the whole pad not be touching the disc?
As for disc being big, its the only one that's right for diameter/height/ 5x112/center bore size to fit the Subaru calipers on the bay spindle  |
trev Jedi Master
Posted: Sat Jan 03, 2015 11:22 am Post subject: |
| oh, wait, is there no pad fitted in the photo you put up? That might explain why it looks unusual to me! |
Posted: Sat Jan 03, 2015 11:49 am Post subject: |
Ah yeah, no pads fitted  |
Posted: Sun Jan 11, 2015 8:01 am Post subject: |
With the pads fitted
