The EASY life
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 24, 25, 26  Next
PostPosted: Mon Sep 30, 2013 6:27 pm    Post subject: Reply with quote
I tried to do it properly and called into a couple of engineering companies, but to no avail..
So i went the table/jig router way..
Did five passes and got the desired 15mm..
PostPosted: Mon Sep 30, 2013 6:59 pm    Post subject: Reply with quote
Looks like somebody has been having some serious fun.
splitbusvanatic
PostPosted: Tue Oct 01, 2013 9:59 am    Post subject: Reply with quote
Yeeeesss.
Good man.
Nice to see some else is as crazy as I am.
How you gettin on with the adapter plate. To bolt to engine ?
I'm making up my drive shaft adapters at the minute.
PostPosted: Tue Oct 01, 2013 3:09 pm    Post subject: Reply with quote
I am definitely happier when im cutting something kai.. Grin
After seeing your thread sbv. I thought 'why the hell not'.. plus id never used a router before and it seemed the perfect excuse..lol
Im woosing out and buying Tims adaptors ,for both engine and drive shafts..
trev
PostPosted: Tue Oct 01, 2013 5:43 pm    Post subject: Reply with quote
I'm really liking the table/router solution to DIY gearbox adaptation. I think I'll be following that route myself soon. I have a duff Passat box here to practice on too so I'll be more confident going at the box I will actually use.
69Bay
PostPosted: Tue Oct 01, 2013 6:43 pm    Post subject: Reply with quote
Great work, good to see somebody else going the upside down gearbox route... Just about to start my conversion so will be watching this with great interest Happy
1969 Baywindow - soon to be TDI
PostPosted: Thu Oct 03, 2013 12:30 pm    Post subject: Reply with quote
Hey 69bay Hello .. If you've seen the last 12 pages then you'll know it should be good for a giggle if nothing more Laugh Out Loud
ohhhh yesssss... shiney stuff
Superleggo
PostPosted: Thu Oct 03, 2013 8:50 pm    Post subject: Reply with quote
Great effort I think I will be joining this club soon
69Bay
PostPosted: Fri Oct 04, 2013 6:03 pm    Post subject: Reply with quote
Oooohhhh Grin
You're using an a4 engine and box aren't you? I need to get in touch with Tim and get my adaptor plate ordered too.
Did you think about getting the gear linkage adaptor from him too or are you going the cable route?
PostPosted: Fri Oct 04, 2013 6:19 pm    Post subject: Reply with quote
The happy couple reunited again...
Had enough time to get it back in on the engine mounts,and this is the space i have at the gearbox mount end.
69bay.. Im going down the cable set up route dude... looking at parts atm.. Grin
69Bay
PostPosted: Fri Oct 04, 2013 8:49 pm    Post subject: Reply with quote
Wow, you don't hang around! I like it Happy
69Bay
PostPosted: Fri Oct 04, 2013 8:53 pm    Post subject: Reply with quote
Easy, did you have to do anything with the starter, read about cutting a new hole and welding up old one any pics of yours?
Page 12 of 26
