Time for an update.....
Goto page Previous  1, 2, 3 ... 23, 24, 25 ... 27, 28, 29  Next
PostPosted: Tue May 21, 2013 5:08 pm    Post subject: Reply with quote
Cheers....there's more.....but Flickr isn't turning out to be very user friendly so you won't be able to see it....what am I doing wrong?
Dump valve now mounted , conveniently just needed to reverse the nozzle on it
[img]http://www.flickr.com/photos/95888253@N03/[/img]
Obonobo
PostPosted: Tue May 21, 2013 5:44 pm    Post subject: Reply with quote
Engine by richbaker78, on Flickr
In the HTML/BBCode menu of FLickr, go to BBCode and find the link there
Nice childrens playhouse, where's that in the bus, didn't notice it in earlier posts Wink
Greetings from Sietze
PostPosted: Wed May 22, 2013 8:54 pm    Post subject: Reply with quote
cheers for the help Obonobo - seems obvious now im on the laptop - on a ipad that option didn't show! hopefully it will work now?!! if it does heres the calorifier now mounted behind the bulkhead.
also no need for the spare wheel well so that got chopped.......
there is a void next to the fuel tank that is wasted space so perfect for the ECU and relays etc in a nice box....it will have a lid
with the chargecooler in place battery access is difficult so the plan is to stack the leisure and engine batteries one over the other and make more efficient use of the space. access to the lower battery will be through the bottom of this box leaving the other battery tray for the air tank and valves
PostPosted: Sun Jun 02, 2013 9:34 pm    Post subject: Reply with quote
bit more progress....
I am using a York air conditioning pump for my air suspension - I bought a recon one a few years ago off ebay but it comes with a v belt - got this machined for me to run a multi grooved belt (thanks Jp) so can start mounting this soon!
before and after....one on the left was a 99p bargiain on ebay!
made the lid and lock for the upper battery box...this is strengthened underneath to avoid flexing.
Also made the removable floor to provide access to the lower battery....
[/img]
Superleggo
PostPosted: Tue Jun 04, 2013 7:32 am    Post subject: Reply with quote
neat idea . Good use of space.
Obonobo
PostPosted: Tue Jun 04, 2013 2:54 pm    Post subject: Reply with quote
Nice progress!
PostPosted: Wed Jul 03, 2013 8:11 pm    Post subject: Reply with quote
been busy on Jps but got a bit more done.....
Many years ago when I started this project, key locks didn't exist for when you go in the sea, so I made my own hidden behind the rear plate with a combi lock....however now I have a key lock its no longer required os I removed it, plus I wanted to modify the no plate light....this one is from a t5 - nice little unit and easy to fit. before
[/img]
after
I also want a bike rack system built into the van a bit like Vauxhall corsas have which will be a multi purpose mount for tow bar / rear mounting for storage box etc...so me & JP started on this - fortunately vw made three factory tow bar mounts on the chassis rail which wre handy to mount the outer slide tubes....
more to come....
Superleggo
PostPosted: Mon Jul 08, 2013 10:10 pm    Post subject: Reply with quote
Nice thinking on the bike rack. I was thinking the whole rear bumper could pull out but too keen to get the van on the road so not made it yet
PostPosted: Thu Sep 12, 2013 9:30 pm    Post subject: Reply with quote
bike rack brackets....fit to the original tow bar mounts
I had a Brazilian bumper as I like the slash cut....but it was a bit bent so a bit of judicious pulling got it sorted....
bike rack fully extended
bike trial fit! just needs a support system now (im working on it)
also some progress with York pump mount on engine....just alternator to go.
PostPosted: Fri Sep 13, 2013 7:15 pm    Post subject: Reply with quote
The rock and roll seat is brilliant, the storage/access panels are brilliant and the bike rack....well.... brilliant...
At the end of the build, is this bus going to turn out to be a transformer....
In disguise Grin
PostPosted: Fri Sep 13, 2013 10:57 pm    Post subject: Reply with quote
easy-does-it wrote:
At the end of the build....
Laugh Out Loud Laugh Out Loud this build will never end theres more chance of you having an trouble free family holiday in your bus Grin
I can't wait for the invisible button install that's comming up on his to do list Eeeek
Grin
PostPosted: Sat Sep 14, 2013 12:07 am    Post subject: Reply with quote
yeah, but there's more of a chance this bus gets a invisibility cloak than there is me having a happy trouble free build.. Laugh Out Loud ..bring on the clingons
Page 24 of 29
