2.5 na loom help
rusty69bus
PostPosted: Sun May 26, 2013 6:08 pm    Post subject: 2.5 na loom help Reply with quote
after a long break, i'm getting on with the wiring.
as i've left it so long i'm having trouble remembering what went where, so i have started to trace some wiring.
where can i find a wiring diagram for a 98 legacy 2.5 quad cam with a I9 ecu.
rusty69bus
PostPosted: Fri May 31, 2013 6:58 pm    Post subject: Reply with quote
being looking everywhere, usa sites, czech and russian all showing wiring diagrams so close but not right........................
but maybe i may have struck gold, a treasure trove of pdf's
http://jdmfsm.info/Auto/Japan/Subaru/
Guesty
PostPosted: Tue Aug 20, 2013 4:49 pm    Post subject: Reply with quote
Hi Rusty,
Have you found the diagrams yet? Cant believe how hard it is to fin the info.
thanks
Guesty
Guesty
Hi Rusty,
thanks
Guesty
chrismcnaz
PostPosted: Fri Jan 17, 2014 2:38 pm    Post subject: Reply with quote
Hi Rusty, I found this site which is fantastic for wiring diagrams, it may be of help to you.
http://www.glasairproject.com/GlasairI/index.htm
Incidentally, how easy/difficult are you finding doing your own loom? I'm thinking of tackling mine myself.
EJ25 Conversion Planned!
Automods
PostPosted: Tue Jan 21, 2014 5:02 pm    Post subject: Reply with quote
I'm bashing my head against a wall with this, just cant seem to find ANY information relation to the immobiliser, on a 98 Legacy.
Not a single wiring diagram shows the connections between the immo ECU and Engine ECU.
If you make any progress would be very interested
chrismcnaz
PostPosted: Wed Jan 22, 2014 6:07 pm    Post subject: Reply with quote
Can Subaru themselves help? Just a thought.
Automods
PostPosted: Thu Jan 23, 2014 11:25 am    Post subject: Reply with quote
Without the Vin and reg number of the original car, they wont even talk to you.
chrismcnaz
PostPosted: Thu Jan 23, 2014 4:11 pm    Post subject: Reply with quote
Wow ok, I'll make sure I hang on to mine then Eeeek
rusty69bus
PostPosted: Fri Jan 31, 2014 5:49 pm    Post subject: Reply with quote
chrismcnaz, follow the link and give it a try.
steve_d
PostPosted: Sat Feb 01, 2014 8:11 pm    Post subject: Reply with quote
Rusty
Can you describe the ECU connector?
I have a 97 donor and the connector is a single, white connector with 88 pins.
I'm also trying to find the wiring info for mine.
Both the sites suggested above (jdmfsm & glasair) do not help me as I believe they are US spec systems which seem to be completely different.
I have the loom spread out all across my lounge floor.
Steve
rusty69bus
PostPosted: Wed Feb 12, 2014 2:42 pm    Post subject: Reply with quote
all i can say is i'm going by the pic of the ecu plug and wire colours.
http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/1998/Wiring%20Diagrams/1998_Legacy_ECU_I-O.pdf
