Rjes subaru turbo bellhousing , wiring,heads,manifolds ect
easy-does-it
PostPosted: Sat May 18, 2013 8:18 pm    Post subject: Rjes subaru turbo bellhousing , wiring,heads,manifolds ect Reply with quote
Wanted to keep hold of this lot for that 'just in case' senario , but realistically i can't ever see it happening...
Rjes turbo bellhousing with clutch shaft and urethane fitting kit. Comes with all bolts, fitting guide cd, master cylinder bracket and both front and back T25 master cylinders ( i know, there not in the pic).
Rjes reversed throttle
Rjes reversed water manifold
'92 legacy turbo engine loom and home modified wiring loom with ecu(not pictured),throttle
Inlet manifold, a pair of cylinder heads, turbo(not pictured) , MAF (although the cone filter isn't included) and as many bits and pieces i have left over from the conversion
£800..
'76 bay going superfly TDI
easy-does-it
PostPosted: Sun May 26, 2013 7:13 pm    Post subject: Reply with quote
Bellhousing kit + t25 slave cylinders
reversed inlet
£550..
PostPosted: Sun May 26, 2013 10:07 pm    Post subject: Reply with quote
How much for the reversed water manifold on its own?
paulvandenton
PostPosted: Mon May 27, 2013 3:12 pm    Post subject: yes please Reply with quote
reversed inlet
£550..
I will take it!'
where r u?
easy-does-it
PostPosted: Tue May 28, 2013 1:13 pm    Post subject: Reply with quote
Sorry Rich i don't want to separate the kit just yet..
Had a PM from Paul. He got a telling off from his other half, so kit is still for sale..
PostPosted: Wed May 29, 2013 9:58 am    Post subject: Reply with quote
No worries, let me know if you change yer mind. Good luck with sale. Rich
Ghia
PostPosted: Sat Jun 01, 2013 11:47 am    Post subject: Reply with quote
You have PM
MG
1989 Syncro 16 2.5TDi Westfalia Conversion Limey
AirWRX
Location: In the East of the Anglia! but mostly at work!!
PostPosted: Sun Jun 02, 2013 7:27 pm    Post subject: Reply with quote
you have pm Hello
easy-does-it
PostPosted: Tue Jun 04, 2013 6:51 pm    Post subject: Reply with quote
Provisionally sold.. Happy
easy-does-it
PostPosted: Wed Jun 05, 2013 7:27 pm    Post subject: Reply with quote
Main wiring loom, Engine loom,Ecu and inlet manifold £100
Or £200 for everything left... you'll only need a block and you'll have a complete set up
Tomasz
PostPosted: Wed Jun 05, 2013 8:34 pm    Post subject: Reply with quote
Hi
I'm not sure but wanted to ask if you still have the Rjes reversed throttle?
If it's still available I'd be very i interested in buying it.
Thanks
Thomas
Calm Bug
easy-does-it
PostPosted: Thu Jun 06, 2013 6:32 pm    Post subject: Reply with quote
Sorry mate it's gone. Even if this sale falls through i've got another buyer lined up for the lot..
