easy-does-it Jedi Guardian
Posted: Sat May 18, 2013 8:18 pm Post subject: Rjes subaru turbo bellhousing , wiring,heads,manifolds ect |
Wanted to keep hold of this lot for that 'just in case' senario , but realistically i can't ever see it happening...
Rjes turbo bellhousing with clutch shaft and urethane fitting kit. Comes with all bolts, fitting guide cd, master cylinder bracket and both front and back T25 master cylinders ( i know, there not in the pic).
Rjes reversed throttle
Rjes reversed water manifold
'92 legacy turbo engine loom and home modified wiring loom with ecu(not pictured),throttle
Inlet manifold, a pair of cylinder heads, turbo(not pictured) , MAF (although the cone filter isn't included) and as many bits and pieces i have left over from the conversion
£800.. _________________ '76 bay going superfly TDI |
Posted: Sun May 26, 2013 7:13 pm Post subject: |
Bellhousing kit + t25 slave cylinders
reversed inlet
£550.. _________________ '76 bay going superfly TDI |
Posted: Sun May 26, 2013 10:07 pm Post subject: |
| How much for the reversed water manifold on its own? |
paulvandenton Padawan
Joined: 10 Jun 2010 Posts: 58 Location: Bethnal Green
Posted: Mon May 27, 2013 3:12 pm Post subject: yes please |
reversed inlet
£550..
I will take it!'
where r u? |
Posted: Tue May 28, 2013 1:13 pm Post subject: |
Sorry Rich i don't want to separate the kit just yet..
Had a PM from Paul. He got a telling off from his other half, so kit is still for sale.. _________________ '76 bay going superfly TDI |
Posted: Wed May 29, 2013 9:58 am Post subject: |
| No worries, let me know if you change yer mind. Good luck with sale. Rich |
Ghia Initiate Jedi
Posted: Sat Jun 01, 2013 11:47 am Post subject: |
You have PM
MG _________________ 1989 Syncro 16 2.5TDi Westfalia Conversion Limey
AirWRX Initiate Jedi
Joined: 31 Dec 2011 Posts: 34 Location: In the East of the Anglia! but mostly at work!!
Posted: Sun Jun 02, 2013 7:27 pm Post subject: |
you have pm  |
Posted: Tue Jun 04, 2013 6:51 pm Post subject: |
Provisionally sold..  _________________ '76 bay going superfly TDI |
Posted: Wed Jun 05, 2013 7:27 pm Post subject: |
Main wiring loom, Engine loom,Ecu and inlet manifold £100
Or £200 for everything left... you'll only need a block and you'll have a complete set up _________________ '76 bay going superfly TDI |
Tomasz Padawan
Posted: Wed Jun 05, 2013 8:34 pm Post subject: |
I'm not sure but wanted to ask if you still have the Rjes reversed throttle?
If it's still available I'd be very i interested in buying it.
Thanks
Thomas _________________ Calm Bug |
Posted: Thu Jun 06, 2013 6:32 pm Post subject: |
Sorry mate it's gone. Even if this sale falls through i've got another buyer lined up for the lot.. _________________ '76 bay going superfly TDI |
