splitscreen driveshafts/ 1300 gearbox
coolyeti
PostPosted: Wed May 08, 2013 1:17 pm    Post subject: splitscreen driveshafts/ 1300 gearbox Reply with quote
Hi new to this forum hope someone make things clear , purchased a Brazilian splitscreen supplied with Subaru engine not fitted a 1300 gearbox not fitted my question is can I fit original spltter driveshafts to 1300 gearbox without to much fuss
tuzza123
PostPosted: Wed Jun 19, 2013 4:31 pm    Post subject: Drive shafts Reply with quote
Has your van got still got the original gear box and reduction boxes if so these will have to be ditched and IRS suspension & drive shafts from either a beetle or early bay.
Fitting kits are available from quite few UK suppliers.
If it has got IRS (independent rear suspension) you will need the 1303 c/v joints on the gearbox only if using bus set and 1303 c/v joints on both drive shaft ends beetle set up.
My personal choice is early bay parts
https://www.facebook.com/media/set/?set=a.2644701604126.2139606.1453214181&type=1&l=5973b121e3
