1971 Bay Window with Ford 1.8 Turbo Diesel
Goto page Previous  1, 2, 3 ... 15, 16, 17, 18  Next
PostPosted: Tue Jan 22, 2013 11:58 pm    Post subject: Reply with quote
A Long overdue update as I thought I better upload some pics from last year (early last year looking at the dates on the pics oops)
OK last update I was somewhere in the middle of this...
I managed to get the engine running but it was a little up and down on the revs.. this maybe due to the fact I have an EGR module missing which a lot of things seem to connect too but hopefully not as I've lost the will trying to find the missing module.
Next up was sorting the steering column on the EPS.. my aim is to try and keep the column as simple as possible retaining the orig stalks etc.. I had a holder made by my local machine shop to house the top bearing and have the correct OD for the indicator stalks to clamp to..
With the wheel on
Neat little ignition set up made by rb78
New Cam belt.. soooo easy with the way the engine mounts in these babies Grin
New Exhaust using a back box from a 1990 Sierra.. nothing fancy for the dirty derv hopefully tucked away and keep the noise down
All out of sight with valance and bumper on
Also fitted some 'drip trays' that some guy on early bay was making/selling which seem to work a treat and stop droopy bumper.
Hole made to make way for pipe work over the torsion tube
And boxed in
Also been playing about with the spit in a final push to get it finished
Issue with tyres fouling on bulkhead
Solved with smaller tyres Grin
There is more progress and will hopefully be much more with deadline to get bus on the Road for May for my Niece's Prom ! But I think that is enough for now Grin
PostPosted: Wed Jan 23, 2013 9:52 am    Post subject: Reply with quote
Coming soon in the next instalment... shiny new driveshaft spacers.... (said in a deep gravelly voice)
Grin
Superleggo
PostPosted: Sun Jan 27, 2013 10:12 pm    Post subject: good progress Reply with quote
Good to see some progress JP. Nice looking Spit as well
mychatype3
PostPosted: Thu Mar 21, 2013 6:12 pm    Post subject: Reply with quote
good work going to be a fantastic Bay.
Kind regards mycha
PostPosted: Sun Apr 07, 2013 9:07 pm    Post subject: Reply with quote
Think its time you updated...heres a start Grin
Engine Cleaned up and assembled.
Gearbox has the new driveshaft spacer bolted onto it which works a treat.. big up SW Engineering for making these.
Steering reassembled after issue found with a bit of rubbing.. thought better to fix now rather than annoy me later. Also given a lick of paint
Some RB Handywork on scoop for Charge Cooler Rad
PostPosted: Mon Apr 08, 2013 11:39 am    Post subject: Reply with quote
Added comments to above.... but need to get my camera out and take some snaps of...
Engine in
Brakes all bled and working
Accelerator connected
D Shafts on
Clutch connected and now actually working hopefully.
Pipework all connected (and there is a lot of it)
Charge Cooler Pump mounted with all pipework done upto the Rad.
So Basically once scoop and CC rad fitted I'm hoping I should be able to fire it up using some crude wiring and take it for a spin ! Then it'll be a mission to sort all the wiring properly.
steamo
PostPosted: Thu Apr 11, 2013 9:44 pm    Post subject: Reply with quote
Awesome work look forward to seeing another Ford up and running!
Nearly time for my MOT again Eeeek Did just over 2000 miles last year. Sorting interior at the mo for first big trip to a friends wedding in Sweden this summer. Hope it passes!! Also not looking forward to the fuel bill, could do with a diesel like you.
PostPosted: Wed Apr 24, 2013 11:28 am    Post subject: Reply with quote
Great news steamo on yer 2k last year looking forward to racking up some miles myself soon... not looking forward to the MOT with the amount of mods on my bus.. need to find a person who knows nothing about Type 2's.
We have Air poor mans air but should still be very useful for offroad/ speed bumps etc at low speeds.
Massive big up to Mycha for his advice and online support with this
Thanks to RB78 to help fit which took all of 30 mins Grin
The Air Shox
Straight bolt on replacement for orig shox just need a 2mm washer to get them straight.
Dropped
Popped
Also RB's master piece that is the Charge Cooler Scoop all fitted up to the rad.
Spending a lot of time on wiring now which is not worthy of pics, picture a mass of old wires that need tidying new connectors, replacing etc.. I am able to start on the key now which good.. next stop lights then a blast up the road Grin
Did I mention I drove it out the garage onto the driveway under it's own steam... first time it's done that in 6+ years ouch ! no reverse to get it back in though Sad
PostPosted: Wed May 22, 2013 11:09 am    Post subject: Reply with quote
After too much head scratching on how to get a contact from my horn button to the relay I decided to buy a a remote controlled relay thing off ebay and use it to trigger the horn.
This is the fob which I removed the inners from
This is the inners
Wires Soldered on
This is the box which is triggered wired into the horn relay
Remote inners connected to horn button
PostPosted: Wed Jun 05, 2013 10:03 pm    Post subject: Reply with quote
drum roll...........
A mere 7ish years in the making and the MOT man he say YEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSS
MexWave
Obonobo
PostPosted: Thu Jun 06, 2013 10:14 am    Post subject: Reply with quote
Well done, looking great! Where's your first trip headed?
Greetings from Sietze
PostPosted: Thu Jun 06, 2013 11:24 am    Post subject: Reply with quote
Kwikfit to get the Tracking done Grin
Plenty of little jobs left to do and will use it for commuting to work for a while to gain some confidence in it
Page 16 of 18
