Superleggo Jedi Master
Posted: Mon Jan 23, 2012 10:19 pm Post subject: |
The PVC will not be attacked by the brake fluid as many of the bottles that brake fluid is fupplied in are PVC. I doubt that the suppliers will fluon coat bottles at this price.
The pressures in the clutch pedal are nowhere as high as brakes. The Austin Montegeo had a PVC clutch pipe line if I remember correctly. I had one of these in a Series 2A Land Rover for 15 years running a Montegeo TD conversion.
however Is it worth the effort when any flexible brake hose will do a better job for £3 |
sven Jedi Guardian
Posted: Fri Jan 27, 2012 8:36 pm Post subject: |
I've got an explanation for the level sinking in the test hose. The hose is softened up a bit and that makes it going from oval to perfect round - volume increase.
Next gearbox upgrade (VAG 012) which happens pretty soon I will use PVC hose. |
sven Jedi Guardian
Posted: Wed May 16, 2012 8:40 pm Post subject: |
| Still hanging, no leaks, hose is fresh as before. |
sven Jedi Guardian
Posted: Mon Jan 21, 2013 12:15 pm Post subject: |
Guess what, it's still dry.  |
sven Jedi Guardian
Posted: Fri Mar 29, 2013 9:15 pm Post subject: |
sunchangping Wannabe
Posted: Mon Sep 16, 2013 8:20 am Post subject: |
I've marked the level every now and then since it sank a bit the first days, mostly because of airbubbles that releases.
___________________________________________________________________
"Do you know those times when you've been put through so much pain you couldn't bear it? Well, that's reality for you."
I have been a FunForFreedom survivor since 7/2/12!Runescape Gold
RS Gold WOW Gold
Supporting Leon X Zara! <3
I have a blog! |
sven Jedi Guardian
Posted: Thu Jul 17, 2014 6:49 pm Post subject: |
Remember my hose test?
It is still ongoing.
The hose is fresh and alive.
Posted: Thu Jul 17, 2014 10:39 pm Post subject: |
Has it dropped much since the original shrinkage?
It's this kinda stuff that makes this forum what it is
Keep the updates coming  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
sven Jedi Guardian
Posted: Sat Jul 26, 2014 8:50 pm Post subject: |
Yeah, I'll make a new post in three years.
The level has been steady for the last two years. I still think the initial shrinkage was the hose that got more circular. The PVC is super fresh. |
