Engine 2 Trans -change clutch to VW or input shaft to Subaru
M@H
PostPosted: Mon Feb 18, 2013 8:51 pm    Post subject: Engine 2 Trans -change clutch to VW or input shaft to Subaru Reply with quote
..as per the title really. Happy
So the VW input shaft in my 002 box is smaller than the Subaru one (no surprise to anyone) so I think I have the two choices.
I have a decent clutch with my Subaru engine so part of me says buy a Subaru input shaft from Richard at RJES (along with a bell-housing), but then I don't really know what other options are around for clutch plates with VW centres that will tie up with the Subaru flywheel etc etc
Your thoughts on this are much appreciated.
Cheers,
Matt.
Obonobo
PostPosted: Sun Feb 24, 2013 8:39 pm    Post subject: Reply with quote
Hi
I run a 2.2 with a 091 box. Standard VW shaft, standard Subaru pressure plate, but used VW's biggest (=280mm) friction plate. It's the one for 2l VW engines, if I'm not mistaken. I just drive normally, not trying to win 1/4 miles. So the VW plate holds up. But when I put the pedal down with low speeds, the clutch slips a little. Not sure if anyone else has that problem, though; never heard anyone else complain about this.
Greetings from Sietze
PostPosted: Mon Feb 25, 2013 2:56 pm    Post subject: Reply with quote
i had a subaru turbo pressure plate with t25 friction plate and its never been a problem,but if you use rjes shaft and bellhousing there is no limit what you can use really ,im using sti stuff in my car Grin
