absence of fuel return feed
lesjones59
PostPosted: Tue Jan 29, 2013 10:30 am    Post subject: absence of fuel return feed Reply with quote
Hi guys, I have a bay window with a n/a ej20 engine, which intermittently runs really well, much of the poor running seems to related to ecu matters I intend to get this converted to a megasquirt system next year.
The fuel system does not include a return to the tank, will this cause much of problem ?
Obonobo
PostPosted: Tue Jan 29, 2013 12:36 pm    Post subject: Reply with quote
Then where does excess fuel go now? Is your fuel system dumping it somewhere?
Don't know whether it would matter, running-wise. I would say no.
Greetings from Sietze
lesjones59
PostPosted: Tue Jan 29, 2013 1:06 pm    Post subject: Reply with quote
I think its just a blind circuit, so it remains pressurised and the back pressure stops fuel flowing , that's why I'm worried it might cause problems
Obonobo
PostPosted: Wed Jan 30, 2013 7:16 am    Post subject: Reply with quote
Then it might be that the injectors are not getting their required fuel amount and pressure. I guess it is easy to check: hook up a hose to the return feed and let it dump fuel in a bucket or something and see how it runs?
nick1973
PostPosted: Fri Feb 08, 2013 9:04 pm    Post subject: fuel return Reply with quote
it does make a differnce i had a problem with a 2.2 not having enough pressue the fuel pressure regulator had dies or dried up i choked the return pipe so the pressure built up and the engine would run but the engine ran badly if you have a good running van and crimp the return pipe you will see what i mean
Joel
PostPosted: Mon Feb 11, 2013 10:02 am    Post subject: Reply with quote
It makes a huge difference, that;s how the efi fuel system works.
it is a loop system, dumping back into the tank and as the load increases the pressure reg restricts how much goes back to the tank so more pressure is supplied the injectors.
If you have the return at the regulator just blanked off I'm amazed you can even get it to run at all, the fuel rails would be getting quite hot, that's another part of the system returning the fuel to the tank so it can cool off.
