Connecting a modified Scooby loom to a bay window existing w
Hayleyjosephfrances
PostPosted: Thu Nov 29, 2012 2:23 pm    Post subject: Connecting a modified Scooby loom to a bay window existing w Reply with quote
PLease could someone help me with a wiring question for my conversion. Simple really how and what do I need to connect to the scooby wiring loom to run the gauges at the front on the dash on my early bay window. Alternator light, oil pressure, ignition switch etc.... I am trying to collect all the information before I start the conversion. diagrams and descriptions would really help. Engine is a EJ20 non turbo. Thanks
Mark
Looking forward to reliability and a few less trips on a recovery truck
PostPosted: Sat Dec 01, 2012 11:40 am    Post subject: Reply with quote
What year?
to make the vw gauges work you'll need to connect the alternator light and the oil pressure light.
you'll need to supply the loom with +12V, obviously a switched +12V, then you get into what the ECU will require, ecu memory +12V, vss, neutral position switch, radiator relays oh and you should install the engine chek light too.
and dont forget to install a coolant temperature gauge, another hurdle you'll have to over come.
loads of information in the forum though.
Thierri018
PostPosted: Sun Jan 19, 2020 12:54 pm    Post subject: Re: Connecting a modified Scooby loom to a bay window existi Reply with quote
Hayleyjosephfrances wrote:
PLease could someone help me with a wiring question for my conversion. Simple really how and what do I need to connect to the scooby wiring loom to run the gauges at the taxi aƩroport front on the dash on my early bay window. Alternator light, oil pressure, ignition switch etc.... I am trying to collect all the information before I start the conversion. diagrams and descriptions would really help. Engine is a EJ20 non turbo. Thanks
Mark
I know you are very experienced in this matter very seriously.
