DK box linkage mod..help to sort it..
BlackCosmos
PostPosted: Fri Oct 05, 2012 8:56 am    Post subject: DK box linkage mod..help to sort it.. Reply with quote
ok still havnt managed to resolve my DK box ive had fitted to my subaru conversion t25..can anyone recommend someone whod be able to sort linkage out?? preferably someone whos done it before and prefer if in essex but if not i"ll get it there..been sitting for a couple months after my mechanic gave up on it!!
easy-does-it
PostPosted: Fri Oct 05, 2012 12:29 pm    Post subject: Reply with quote
What problems are you getting? are you using a DK or similar linkage?
'76 bay going superfly TDI
BlackCosmos
PostPosted: Fri Oct 05, 2012 2:56 pm    Post subject: Reply with quote
yep got the DK linkage to box cut and shut with tubing so adjustment can be made..but having no joy??
easy-does-it
PostPosted: Fri Oct 05, 2012 9:26 pm    Post subject: Reply with quote
I've never had a T3 so im just guessing...
First off ,did you check the box went into all gears before you installed it?
what box did you have before? im just wondering cos when i got my selector rods off ebay it stated that it came with the right gear stick, now it might be ebay talk but im wondering if there's different amount of movement in the different sticks and that's causing grief?....
sorry i don't know anyone that could come over and have a look Sad
BlackCosmos
PostPosted: Sat Oct 06, 2012 8:02 pm    Post subject: Reply with quote
did have a 5 speed went to 4 speed as told theyre stronger and better suited to conversion..even a garage recommendation as long as theyve done it before..dont need any more nasty surprises!! does go into gear if i select by hand so box seems ok..
