graham-e Padawan
Joined: 30 Aug 2008 Posts: 78 Location: Lake District
Posted: Mon Feb 14, 2011 12:00 am Post subject: |
At a guess I'd imagine the VW hub would sit inside the sprinter disc (they must be the same PCD).
Then drill the boiler plates to fit inplace of the vw drum's backing plate then bend/cut/weld/magic spell the boiler plate into the correct offset to place the caliper in the right place.
Make sense? _________________ Think......
graham-e Padawan
Posted: Mon Feb 14, 2011 12:33 am Post subject: |
I've read the sprinter is 5x130, so i'm not sure..
I kinda understand what your saying but, I wouldn't know where to begin..
I just want to upgrade my brakes with out spending daft amounts of money, not sure how possible that is  |
Posted: Mon Feb 14, 2011 7:38 am Post subject: |
| graham-e wrote: | I've read the sprinter is 5x130, so i'm not sure..
Just googled it and I'd agree that the sprinter is 5x130,
Perhaps the seller meant Merc Vito which is 5 x 112.
Look at the empi rear disc kit and you'll see the bracket I'm speaking off.
http://www.status-vw.co.uk/shop/en-gb/dept_211.html
Most kits are made this way, infact my Porsche 944 brakes are basically the same except the mount is much fancier as it incorporates the disc backing plate. _________________ Think......
Posted: Mon Feb 14, 2011 7:39 am Post subject: |
Just googles it and I'd agree that the sprinter is 5x130,
redcamper Wannabe
Posted: Mon Sep 17, 2012 3:39 pm Post subject: |
I used 2002 passat discs, had the rear hubs machined slighty to fit inside the discs, then used mk4 golf rear calipers. _________________ is water cooled better than lawn mower no way tonto |
