SubaruVanagon.com and his T-stat questions?
Goto page Previous  1, 2
mackaymanx
PostPosted: Sat Aug 04, 2012 11:01 am    Post subject: Reply with quote
Here is a turbo pump off a EJ20(98) fitted to a EJ22(94), fits no problems. I removed the excess pipes and drill/tapped for B.S.P.T plugs
PostPosted: Mon Aug 06, 2012 8:04 pm    Post subject: Reply with quote
Brill, cheers guys
Mackaymanx, thanks for the photo and tips. I'll be in a bit of a hurry and will probably loop those extra inlets together.
PostPosted: Mon Aug 06, 2012 9:23 pm    Post subject: Reply with quote
I think the outlets are steel, you could mig them up too
ricola
PostPosted: Wed Aug 08, 2012 9:30 pm    Post subject: Reply with quote
I think you are missing the point...
The purpose of the spacer and extra hose is to expose the thermostat purely to the hot bypass flow and give it some distance from the cold return pipe. This system was designed to make sure that the thermostat opened at the correct time in cold climates where the bypass and return effectively mixed and lowered the temperature the thermostat sees, even tho this spacer only moves the stat a small amount it is apparently enough...
http://www.ricola.co.uk
panel
PostPosted: Thu Aug 09, 2012 1:44 pm    Post subject: Reply with quote
^^^ Ah, thx!
EJ20 Turbo bus build
PostPosted: Sun Aug 19, 2012 9:44 pm    Post subject: Reply with quote
Sorry for taking this off at a tangent again. The turbo pump and housing has sorted my dilemma.
Just done approx 700 miles. Engine/cooling/exhaust glitch free. Shame my IGN switch has packed up on the "start" posn
Page 2 of 2
