pmclok Wannabe
Posted: Mon Aug 13, 2012 12:24 pm Post subject: os rear hub problem |
Mucho good advice needed..have a T25 subaru ej22 converted bu the rjes boys..my cv to hub bolts keep undoing themselves after I've torqued em up correctly!!!! Alls well for 20miles then there's starts to go slack when drive is taken up..have tried new hex bolts and new anti-slip washers!!!! All suggestions welcome  |
Obonobo Jedi Knight
Posted: Mon Aug 13, 2012 3:25 pm Post subject: |
Are you also using the two-holed plates (you need them on the transmission-side, 3 pieces, both left and right)? Just asking. And a drop of Loctite should help. _________________ Greetings from Sietze
pmclok Wannabe
Posted: Mon Aug 13, 2012 7:17 pm Post subject: |
| Obonobo wrote: |
Are you also using the two-holed plates (you need them on the transmission-side, 3 pieces, both left and right)? Just asking. And a drop of Loctite should help. |
hi yep will try ht bolts and loctight again!!! |
Posted: Tue Aug 14, 2012 6:36 am Post subject: |
I'm under the impression that's these are stretch bolts and would definetly need replacing in your case. Pretty sure if you went and bought a quality cv boot kit it should come with new bolts. _________________ Think......
