for the timing belt cover , I 'll have a set in carbon if you want , I ll send you pictures if you want when I'll receive mine......
You need to check and change some parts on the flywheel side, the plate at right , the flywheel joint, and some small rubber joint at the screw for checking the rod
thierry
Hey Thierry,
Thanks, the look for my engine is going to be black and stealth so i prefer original covers, but i’m interested in price and photo
Did you have trouble with the flywheel plate etc.?
Joined: 04 Jun 2011 Posts: 71 Location: South of France
Posted: Wed Jul 18, 2012 10:00 am Post subject:
no, a the right of the flywheel, on the engine case you have a black plastic plate, before fitting the engine, change it , replace it by a metal one for STI engine and change all the joint ( flywheel , etc)
change the joint of the 4 camshafts too.
remove the water pump, change the joint, fit a water temp opener GRIMMSPEED, who s open at 70° not at 90°, your water will be refresh before and you will have heather before to !!! You not live in the south of France like me !
thierry
for the belt timing cover you need to pay 450 € + shipping ( double carbon skin in and out , very nice job
