1970 Westfalia S Turbo
Goto page Previous  1, 2
mychatype3
PostPosted: Wed Jul 18, 2012 9:46 am    Post subject: Reply with quote
southcoastcruiser wrote:
HI Mycha
for the timing belt cover , I 'll have a set in carbon if you want , I ll send you pictures if you want when I'll receive mine......
You need to check and change some parts on the flywheel side, the plate at right , the flywheel joint, and some small rubber joint at the screw for checking the rod
thierry
Hey Thierry,
Thanks, the look for my engine is going to be black and stealth Wink so i prefer original covers, but i’m interested in price and photo
Did you have trouble with the flywheel plate etc.?
Greetings mycha
southcoastcruiser
PostPosted: Wed Jul 18, 2012 10:00 am    Post subject: Reply with quote
no, a the right of the flywheel, on the engine case you have a black plastic plate, before fitting the engine, change it , replace it by a metal one for STI engine and change all the joint ( flywheel , etc)
change the joint of the 4 camshafts too.
remove the water pump, change the joint, fit a water temp opener GRIMMSPEED, who s open at 70° not at 90°, your water will be refresh before and you will have heather before to !!! You not live in the south of France like me !
Grin
thierry
for the belt timing cover you need to pay 450 € + shipping ( double carbon skin in and out , very nice job
mychatype3
PostPosted: Fri Aug 03, 2012 2:47 pm    Post subject: Reply with quote
Collecting parts:
Page 2 of 2
