1970 Westfalia S Turbo
mychatype3
PostPosted: Fri Jun 15, 2012 12:13 pm    Post subject: 1970 Westfalia S Turbo Reply with quote
Hello all,
First some introduction I'm almost 37years old and living with my wife and daughter (6months) in the Netherlands. I'm a vw-fan for almost 20years, i droved beetles, typeIII (fastback, notch and squarebacks) this is my first van. Bought it in 2009 from ebay-usa and updated along the way.
See my threat here for all the details:
http://forum.earlybay.com/viewtopic.php?f=2&t=21827
Some futures are Porsche 944 brakes all around, power steering, custom interior and updated camping interior (cooking stove, gas/220/12 fridge)
Done a Wasserboxer notchback in the past and now it's time for some Subaru Turbo power..................... My Westy is going S-Turbo.
I've bought a 2000 Forester with front damage, EJ205 engine, 150.000km on the clock. The plan is to install this with the original 5-speed(reversed) gearbox.
The plan is to collect parts and start the build when engine, loom, gearbox and all the small stuff are inn and detailed.
Rough plan is winter 2013 for the big switch. Now some photo's:
Kind regards from Holland, mycha
PostPosted: Fri Jun 15, 2012 3:57 pm    Post subject: Reply with quote
Welcome fella.
Sweet ride Happy
Ask away. I'm looking forward to a Subaru gearbox conversion.
PostPosted: Fri Jun 15, 2012 4:05 pm    Post subject: Reply with quote
Hi and welcome, great project and a great bus to start with. Like the steering...is that a t25/t3 bevel box you have used?
mychatype3
PostPosted: Sun Jun 17, 2012 8:26 am    Post subject: Reply with quote
THANKS,
The bevel box is T25/T3 with Peugeot 106 pomp and a Vauxhall (rhd) steering rack.
Greetz Mycha
Obonobo
PostPosted: Sun Jun 17, 2012 10:40 am    Post subject: Reply with quote
Hei Mycha,
good to see you here too: you have come to the right place for your convo!
Greetings from Sietze
hanzzz...
PostPosted: Sun Jun 17, 2012 8:13 pm    Post subject: Reply with quote
Couldn't be long before your showed up here!
Can't wait to see this happen...
madmick
PostPosted: Mon Jun 18, 2012 9:34 pm    Post subject: Reply with quote
Hello from sunny Scotland
Love the van, very nice detail work and some real nice photos
Looking forward to the engine transplant.
mychatype3
PostPosted: Tue Jun 19, 2012 12:48 pm    Post subject: Reply with quote
Yesterday evening was demolition time Grin Cleaned up the front, all the bent metal is away, i can now pull the engine out from the front !!!
First up is to replace all the broken parts and let the engine run. I hope the valves etc. are fine. I have to replace the timing belt and bearings. When the engine is ok a friend will do the wiring-loom and i will pull the engine, gearbox, gas tank and everything that is useful.
Parts that need replacing:
Timing belt kit;
Canister;
Left exhaust Pulley;
Timing belt covers;
repair or chance oil heat exchanger;
Greetings Mycha
ricola
PostPosted: Fri Jun 22, 2012 2:49 pm    Post subject: Reply with quote
Great bus, looks like you will obviously be doing a quality job. Love your garage too, must make things a lot easier having a lift!
http://www.ricola.co.uk
paulvandenton
PostPosted: Fri Jun 29, 2012 1:43 pm    Post subject: Reply with quote
awesomeeeeeeee!!!!!!!!!!!!
mychatype3
PostPosted: Tue Jul 17, 2012 1:20 pm    Post subject: Reply with quote
Collecting parts, got a used exhaust pulley in from flea bay Wink
And some new badges arrived from the earlybay threat Grin
Also looking for the following parts (don’t now how they are called Cool)
And a complete timing belt cover (left/right/middle, front and rear)
As anybody has these parts please let me now.
Greetings from Holland mycha
southcoastcruiser
PostPosted: Tue Jul 17, 2012 7:00 pm    Post subject: Reply with quote
HI Mycha
for the timing belt cover , I 'll have a set in carbon if you want , I ll send you pictures if you want when I'll receive mine......
You need to check and change some parts on the flywheel side, the plate at right , the flywheel joint, and some small rubber joint at the screw for checking the rod
thierry
