gear selection problem??
BlackCosmos
PostPosted: Wed Apr 04, 2012 2:12 pm    Post subject: gear selection problem?? Reply with quote
im having problems selecting first gear and reverse is hard to get into gear too..been advised it could need gear selector adjusted..it does drive and select other gears fine from 2nd..its a five speed box in a t25 lhd van..any advice on how to adjust this and is it under spare wheel carrier as cant visible see it clearly..thanks
andysamba
PostPosted: Wed Apr 04, 2012 5:23 pm    Post subject: Reply with quote
its time to lay under bus...
if you have alot of play at gearstick end then you will reqire bushes ,all available at just campers and lots of them [check website has exsploded veiw of complete linkage]. also check your engine mounts are secure.
to adjust shift rod follow the shift rod underneath and you will find a splined part and a collar around it ,mark it first then turn it a couple of spines one way [or other] this will give it more movement in the direction of 1st/reverse.
hope im of some help.
BlackCosmos
PostPosted: Thu Apr 05, 2012 8:35 am    Post subject: Reply with quote
thanks for advice..looks like i,ll be under van for easter..will check mounts too..its got scooby turbo fitted..
andysamba
PostPosted: Sat Apr 07, 2012 9:09 am    Post subject: Reply with quote
if your front mount is all baggy, i had some custom poly bushes made.[got 2 left],if your interested?.
andy
