EJ 22 RUNNING PROBLEMS
tuzza123
PostPosted: Thu Mar 29, 2012 9:08 pm    Post subject: EJ 22 RUNNING PROBLEMS Reply with quote
Starts fine idles fine revs up but only if you open throttle slow if you snap throttle just massive flat spot wont rev shut it down idles fine. same symptoms hot or cold
Joel
PostPosted: Fri Mar 30, 2012 9:11 pm    Post subject: Reply with quote
Have you checked for error codes?
Sounds like the cam or crank position sensor isn't reading.
tuzza123
PostPosted: Sat Mar 31, 2012 10:54 pm    Post subject: EJ22 RUNNING PROPLEMS Reply with quote
Thanks but have read codes non present noticed does improve a bit when really warm
PostPosted: Sun Apr 01, 2012 7:48 pm    Post subject: Reply with quote
Timing belt?
tuzza123
PostPosted: Sun Apr 01, 2012 10:59 pm    Post subject: EJ22 RUNNING PROBLEMS Reply with quote
Hi Thanks for post By timing belt I presume you mean the timing or valve timing
PostPosted: Mon Apr 02, 2012 6:14 am    Post subject: Reply with quote
Yeah your cam belt. Could be a tooth out. Have you had it off?
Yours is a dual cam right?
Griff71
PostPosted: Mon Apr 09, 2012 3:26 pm    Post subject: Reply with quote
This may help as three times now i have had the same problem:
A couple of months back i stalled and when i tried to drive off it would cut out unless i was very light on the throttle. Stopped and checked engine to find a split in my air intake. No fault codes showing. Get me home fix with some tape and was on my way. Obviously replaced hose since.
Another similar problem was a worn knock sensor, however this did come up as an error. However identical symptoms.
Most recently was a worn TPS (throttle position sensor) this should throw a code.
When i did my conversion originally i had alot of problems with fuel surging (i would have no full throttle only half pressed would get me anywhere) however on fitting the filter after the pump and a harder walled fuel line this stopped.
Hope this helps!
89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock)
paulvandenton
PostPosted: Thu Apr 12, 2012 10:12 pm    Post subject: Reply with quote
i had this when i didnt have a fuel injection tank so i guess it was starving the fuel, this made me go through 2 fuel pumps until i got the right tank. Then it would only do that under wide open throttle, but i just got used to it and learned to back off a tiny bit. Anyway good luck!
PostPosted: Thu Apr 12, 2012 10:26 pm    Post subject: Reply with quote
A little birdie told me this problem was due to poor quality fuel lines compressing Wink
