tuzza123 Force Sensitive
Joined: 26 Feb 2011 Posts: 24 Location: Cannock Staffs
Posted: Thu Mar 29, 2012 9:08 pm Post subject: EJ 22 RUNNING PROBLEMS |
| Starts fine idles fine revs up but only if you open throttle slow if you snap throttle just massive flat spot wont rev shut it down idles fine. same symptoms hot or cold |
Joel Jedi Master
Posted: Fri Mar 30, 2012 9:11 pm Post subject: |
Have you checked for error codes?
Sounds like the cam or crank position sensor isn't reading. _________________ 1974 1303 Germanlook Suba-Beetle
Posted: Sat Mar 31, 2012 10:54 pm Post subject: EJ22 RUNNING PROPLEMS |
| Thanks but have read codes non present noticed does improve a bit when really warm |
Posted: Sun Apr 01, 2012 7:48 pm Post subject: |
Timing belt? _________________ Think......
Posted: Sun Apr 01, 2012 10:59 pm Post subject: EJ22 RUNNING PROBLEMS |
| Hi Thanks for post By timing belt I presume you mean the timing or valve timing |
Posted: Mon Apr 02, 2012 6:14 am Post subject: |
Yeah your cam belt. Could be a tooth out. Have you had it off?
Yours is a dual cam right? _________________ Think......
Griff71 Jedi Knight
Posted: Mon Apr 09, 2012 3:26 pm Post subject: |
This may help as three times now i have had the same problem:
A couple of months back i stalled and when i tried to drive off it would cut out unless i was very light on the throttle. Stopped and checked engine to find a split in my air intake. No fault codes showing. Get me home fix with some tape and was on my way. Obviously replaced hose since.
Another similar problem was a worn knock sensor, however this did come up as an error. However identical symptoms.
Most recently was a worn TPS (throttle position sensor) this should throw a code.
When i did my conversion originally i had alot of problems with fuel surging (i would have no full throttle only half pressed would get me anywhere) however on fitting the filter after the pump and a harder walled fuel line this stopped.
Hope this helps! _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
paulvandenton Padawan
Joined: 10 Jun 2010 Posts: 58 Location: Bethnal Green
Posted: Thu Apr 12, 2012 10:12 pm Post subject: |
| i had this when i didnt have a fuel injection tank so i guess it was starving the fuel, this made me go through 2 fuel pumps until i got the right tank. Then it would only do that under wide open throttle, but i just got used to it and learned to back off a tiny bit. Anyway good luck! |
Posted: Thu Apr 12, 2012 10:26 pm Post subject: |
A little birdie told me this problem was due to poor quality fuel lines compressing  _________________ Think......
