Brake booster & master cyl retrofit
Goto page Previous  1, 2
ping
PostPosted: Sat Jan 07, 2012 3:37 pm    Post subject: Reply with quote
Hi, i'm looking at using the subaru legacy servo and mc in my split to replace the cingle circuit one. (as its laying around and free)!
I've asked on a few splitty sites but people ony seem to know about splitty parts or the parts that half a million other people have already used. Can you see any problem in using the legacy mc setup appart from linkage and reservior?
I'm unsure if i would need a residual pressure valve or not. (Keeping drums all round)
gazman
PostPosted: Wed Feb 22, 2012 5:50 am    Post subject: Reply with quote
Sorry for the late reply Ping, I haven't been round much lately.
You could use the legacy bits (with appropriate mods etc) but you shouldn't run a dual circuit m/c and an external proportioning valve. If you don't want to change your current brake bias setup I'd disable the built in prop valve in the legacy m/c. I'm not sure how you do it off the top of my head but I know it can be done, 5mins on Google will tell you
The V6 Lowlight. See the full build here - http://osp.metrohosting.info/kombiv6.html
ping
PostPosted: Wed Feb 22, 2012 5:19 pm    Post subject: Reply with quote
Thanks, i realised i wouldn't need a external proportioning valve but i would need residual pressure valves to keep fluid from leaking back to the mc due to the return springs in the drum brakes.
I have decided not to go ahead with using the legacy brake bits now as i have checked the piston size and found it to be 25 mm dia which i think is far too big and would possibly make my braking worse due to lack of pressure in the hydraulics!
I'm pretty sure i will now follow like a sheep and use the baywindow mc and a vw jim remote servo!!
Page 2 of 2
