Heater bypass
tuzza123
PostPosted: Tue Feb 07, 2012 10:53 am    Post subject: Heater bypass Reply with quote
I can see the point of heater bypass but surely making a bridge between the pipes before heater will affect the water flow when heater is on reducing heat output
steamo
PostPosted: Thu Feb 09, 2012 10:14 pm    Post subject: Reply with quote
You could have a valve switching water flow to either the bypass ot the heater matrix. Thats how it works in an old mini IIRC (normally a cable operated valve) hope it helps.
tuzza123
PostPosted: Fri Feb 10, 2012 7:40 pm    Post subject: heater bypass Reply with quote
Thanks for info have solved problem as the heater have fitted blows into old Vw duct pipe I have made a flap to block output the nice bit is that it is still controlled by origional knob in cab .
I would post a picture but but cannot use this complicated method
