Fuel system in a Subaru Beetle
Tomasz
PostPosted: Fri Feb 03, 2012 10:27 am    Post subject: Fuel system in a Subaru Beetle Reply with quote
Hi guys, I'm creating this topic because I'd like to find out what sort of fuel supply system can be done in a Beetle.
I've made 2 schematics and want to know what you think about them - what your ideas are.
Version 1 without a swirl tank:
Version 2 with a swirl tank:
I'm not sure about the '3rd manifold outlet' line going to swirl tank, if there is more 'air' then fuel it probably should go to main fuel tank which 'breathes'.
Calm Bug
KARMAD
PostPosted: Fri Feb 03, 2012 2:34 pm    Post subject: subaru pump in tank Reply with quote
Hi there, im doing an ej22 in a 1303 and im sorting out the fuel system at the momment. Im doing it the same way as ricola has because its the proper pump for the engine and swirl and baffles all in the tank .so very neat and quiet . let me know how your getting on !
Tomasz
PostPosted: Sat Feb 04, 2012 1:03 pm    Post subject: Reply with quote
I like Rcola's tank set up a lot, yours look as good as his. I was just a bit concerned about cutting fuel tank it's got to be done properly and in my case it means that I need someone to do this for me - I'm not a welder.
I've spoken to a friend of mine yesterday and he mentioned his neighbour who welds motorcycle fuel tanks so fingers crossed I'll have my tank done and the pump will go inside Happy
If that happens I just run 2 8mm fuel lines under the car and can use the Beetle fuel line for the third Subaru 'breathe' line.
For people who don't want or have no option to cut their tanks I'd suggest to keep it simple (I'd do it). For normal everyday driving I'd use the set up of 'version 1' (schematics):
or with a swirl tank:
These just are my suggestions but I think they are ok.
I'd like to thank Joel, his topic on auusievw forum is very helpful and as usual Richard (RJES) his website's packed with lots of very useful info - cheers.
Calm Bug
