tuzza123 Force Sensitive
Joined: 26 Feb 2011 Posts: 24 Location: Cannock Staffs
Posted: Sat Jan 28, 2012 12:11 am Post subject: temp gauge sender |
| Can I replace Subaru temp Gauge sender for after market one matched to a gauge or will the ecu throw a wobblely if so is there any where else it can go |
doppelganger Jedi Guardian
Posted: Sat Jan 28, 2012 12:40 pm Post subject: Re: temp gauge sender |
| tuzza123 wrote: | | Can I replace Subaru temp Gauge sender for after market one matched to a gauge or will the ecu throw a wobblely if so is there any where else it can go |
there are a couple of places in the block you can put an after market one,remove a bung with allan key and replace with the reducer most supply and put new sender in. simples  _________________ vwdrc class rep
Posted: Sun Jan 29, 2012 2:47 am Post subject: |
To expand on Dopplegngers' post....
ECU needs THE Subaru sensor. Jap (old British BPST thread)
But drill n tap whatever thread you want to match your gauge
I did a "thread" on "27TPI" "NPT" a while ago  _________________ The advice you receive on here is worth the paper it's written on.
Griff71 Jedi Knight
Posted: Sun Jan 29, 2012 9:52 pm Post subject: |
Tuzza, you don't actually say what engine you have fitted and into what VW.
Have you used RJES parts including loom?
I have used RJES parts throughout my EJ25 conversion into a T3 crew cab. Rich sets the looms so they work with the VW temp gauge with a resister fitted to correct the temperature. I also have an after market digital gauge in an extra pod on the dash. This is fitted using an in line sender fitted just before the radiator. Gives a spot on reading. _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
Posted: Sun Jan 29, 2012 11:21 pm Post subject: temp gauge |
Hi The bus is 1964 split also I have fitted digital temp gauge I was going to try a resister in the wire just before the gauge if that does not work I will fit the matched sender some way
Thanks for your help |
Joel Jedi Master
Posted: Tue Jan 31, 2012 11:07 am Post subject: |
it depends on the size of the sender.
Some will fit straight into the stock gauge sender port but others will be abit big in diameter.
I found one of mine was bit to big to fit, there is a lip inside the coolant manifold just at the end of the thread that stops them screwing in.
Very delicate use of a drill a tiny bit smaller than the threads cleared it up enough for the sender to fit. _________________ 1974 1303 Germanlook Suba-Beetle
Posted: Tue Jan 31, 2012 7:42 pm Post subject: temp sensor |
Thanks for that but reason i wanted to know I was told that the stock sensor was also used by the ECU but if I use that it gives the gauge a way out high temp reading .
Thanks again |
Joel Jedi Master
Posted: Tue Jan 31, 2012 8:03 pm Post subject: |
Someone has been telling you porkies.
There are actually two sensors side by side on the manifold.
The big brown 2 pin one is the ECU sensor for turning fans on, cold start enrichment etc.
The smaller single wire one is for the temp gauge only.
Posted: Thu Feb 02, 2012 8:49 am Post subject: temp sender |
Thanks that is going to make things simple I can use sensor matched to the gauge.
Thank you for your time and trouble :) :) |
