subaru imobilizer
zero
PostPosted: Thu Nov 17, 2011 6:50 am    Post subject: subaru imobilizer Reply with quote
Hi everyone
i.m hoping you can shed some light on a poblem i have with the subaru imobilzer on my van.i am runniing a 2.0t using a loom from Richard which has been faultless. last weekend it would not start,i did the fault code check and have 53. the imobilzer light was also on, i have not had anyproblems in the past since the conversion. could the imobilzer be playing up ? does the scooby key have a battery in it to help it comunicate with the anntena and imobilzer ? the van has been starting after a while when i have disonected the unit and replaced it.
all help apreciated.
regards
z.
1986 2.0 TURBO T25 TRANSPORTER
zero
PostPosted: Thu Nov 17, 2011 7:29 am    Post subject: Reply with quote
just to add.
when i turn the ign on if the check light is flashing it wont fire if it is not flashing i know it will start.
i do not use a vss never needed one as ran fine.
wen it does start it runs fine,then it may not on the next turn of the key.
z.
zero
PostPosted: Thu Nov 17, 2011 9:41 am    Post subject: Reply with quote
would this be any good ?
http://www.automotiveelectronic.co.uk/cars/subaruimmobiliser.htm
z.
ping
PostPosted: Fri Nov 18, 2011 6:56 pm    Post subject: Reply with quote
Wow, anyone used the bypass thing? Looks like it could help alot of people doing conversions.
PostPosted: Sat Nov 19, 2011 2:56 am    Post subject: Reply with quote
No battery in the key
zero
PostPosted: Mon Nov 21, 2011 7:00 am    Post subject: Reply with quote
update.
van has been fine all weekend.
Mr Elusivestranger can u say what the battery looks like as i tried checking this and on my key there is a small plug on the end if i pull this out there is a small blck rectangular thing that comes out i thought this might be a chip.
regards
zero
PostPosted: Sat Nov 26, 2011 1:50 am    Post subject: Reply with quote
There's no battery as I said earlier. The black bit...do not lose this. Go buy a big, feck off screwdriver & some tape.
Tape the black thing to the screwdriver, or something large
That is the chip. Do not lose it. Never has summit so small gonna cost you so much if it goes missing
Pipe lagging works well to hold your modified screwdriver in the induction loop. You'll have to fiddle a bit with it's placement.
Ohhh, there's no battery in the key that you need to worry about, well maybe for central locking etc but now I've mentioned it thrice....
Happy
simon1291
PostPosted: Sun Dec 04, 2011 9:07 pm    Post subject: Reply with quote
The best thing to do, as I discovered, is to use the original ignition barrel because the reader is very particular about position of the chip. That's probably why it's not being read a slight movement out of range.
autoinnovations-kempston.co.uk
autoinnovationscampervanhire Facebook.
