arthur8804 Wannabe
Posted: Sun Oct 02, 2011 8:30 pm Post subject: new to the forum, lots of questions |
Hello,
I'm settled on doing a subi conversion in my beach buggy. I have lots of questions, so I want to apoligize in advance. My main concern about the conversion is the radiator. I have very little room in the buggy for water cooling but wanted to bounce some questions off of you guys.
I was thinking of putting it here
The problem here is that I am not sure of the air flow. It would be the easiest location and also easiest for plumbing.
Second option is my favorite
I wanted to put into the side pods and put a vent kind of like ones found on a mustang or maybe the hood vent on a Cooper Mini. The plumbing should be pretty easy, but I would need a small radiator (what size is the smallest that I can go)
Third option is this one
I like this option. I would cut away the areas in the scoop and have to move the gas tank to the back (this would be good for the modifications needed to the tank). I could accomidate a bigger radiator here but am not sure if the holes that I would create in the scoop would provide a big enough surface for cooling and air flow. The downside obviously is plumbing.
Your thoughts and expertise will be greatly appreciated. Thanks in advance. |
Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 160 Location: nr Liverpool, uk
Posted: Sun Oct 02, 2011 10:29 pm Post subject: |
I like your second option.
a pair of long thin rads in the pods with some scoops would look good and be functional. _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
arthur8804 Wannabe
Posted: Mon Oct 03, 2011 1:58 am Post subject: |
| I agree. The second option was my first thought and still my favorite. Any insight on what size radiators would be sufficient? I asume that if I went with two small woul not be an issue. Also taking into consideration I'm in California where the weather us always fair. I've been looking for scoops that I can use for this option and I am wondering what kind of opening would be sufficient. Many that I have found are a "slit" type. 10 inches long and maybe 2 inches wide max. Would this work? |
Posted: Mon Oct 03, 2011 10:17 pm Post subject: |
Providing the slits are open enough to allow enough airflow to cool the rads you should be ok.
Make sure you get a good seal between the pods and the outside of the radiators, that way the fan will pull the air through the rad without leakages.
There is a thread on here somewhere with different radiator sizes, have a look through and find something that will fit into the space you have.
Alternatively, try local scrapyards/vehicle breakers for suitable rads.
Here's the thread, something like the Toledo rads might fit your needs, not sure if that model is available over there though....
http://www.vwkd.co.uk/bb/viewtopic.php?t=768 _________________ Located near Liverpool.
Posted: Wed Oct 05, 2011 11:40 pm Post subject: |
Have a look on Aussieveedubbers.com, there's a fair few buggies on there & they're a good crowd
Pete Wood, Buggy Brad & Wes are a few posters to look for _________________ The advice you receive on here is worth the paper it's written on.
