Subaru coolant system
Goto page Previous  1, 2, 3, 4
southcoastcruiser
PostPosted: Tue Aug 02, 2011 7:07 am    Post subject: Reply with quote
Here There s always 30/35 degree .I think that I need to place scoops behind the rads. A friend of me who have a subaru shop (http://www.racealtered-import.com/) say to me that his impreza go always at 90 degree and I don t pass the 100 .
I can fit another rads(a small and long one)at the rear of the bus ,i have 2 exit pipes on the water pump
southcoastcruiser
PostPosted: Sun Aug 14, 2011 11:29 am    Post subject: Reply with quote
I thinks there a problem with the waterpump, I ve changed it but it was not the same model , this one have 2 small exit in supplies, I ve read that the timing belt can make trouble if it was not tended enought
thierry
smurf
PostPosted: Tue Aug 30, 2011 3:48 pm    Post subject: Reply with quote
Would this work in a '77 westfalia? I'm thinking of running this cooling system. Let me know what you think.
RatCamper
PostPosted: Wed May 02, 2012 11:51 pm    Post subject: Reply with quote
I have a bit of a question. I recently chanced across something in a Gregory's manual that says the weird temperature sensor thing on my manifold / coolant crossover pipe is a thermo switch for a fan. Is there any reason i should continue using my adjustable one which is theoretically set to the same temp as the sensor anyway?
PostPosted: Sat May 19, 2012 3:26 am    Post subject: Reply with quote
Photo?
Subaru designed the coolant system with:
1/ Temperature sensor
2/ VSS
These 2 are related.
At low speeds (via VSS) the ECU tells the fan(s) to start up at a lower temperature than at a higher speed.
I have posted a table from the manual on here - it was a fair few years ago though
ricola
PostPosted: Sat May 19, 2012 8:01 am    Post subject: Reply with quote
the manifold has two temperature sensors. One for the dash gauge and one for the ECU, neither of them directly control the radiator fan (the ECU does)...
http://www.ricola.co.uk
Joel
PostPosted: Sun May 20, 2012 12:23 am    Post subject: Reply with quote
RatCamper has a carbed EA81 engine, its only an on/off sensor and I would let sleeping dogs lie if your external one is working fine.
Page 4 of 4
